Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 25-03-2012, 14:52
enrique's Avatar
enrique enrique is offline
FRC #1251 (Tech Tigers)
Team Role: Electrical
enrique will become famous soon enough
Send a message via Yahoo to enrique
Gyro code causes a crash
The code below causes the crio FRC program to crash. Anyone know why:
CONFIGURATION:
One KOP gyro hooked up to port 6 of the analog break out. The module is on slot 1. I tried passing the slot number 1 in, but it made no difference.
CODE:
class RobotDemo : public SimpleRobot
Gyro TheGyro;
public:
RobotDemo(void):
TheGyro(6)
float TheAngle = TheGyro.GetAngle();
printf("The Angle is %f \n", TheAngle);
CONSOLE OUTPUT:
>>>>ERROR: A parameter is out of range.: moduleNumber and/or channel (must be accumulator channel) ...in InitGyro() in C:/WindRiver/workspace/WPILib/Gyro.cpp at line 32
dDistance is 21.347803
program
Exception current instruction address: 0x00000000
Machine Status Register: 0x0008b012
Condition Register: 0x28000484
Task: 0x11e49e8 "FRC_RobotTask"
0x11e49e8 (FRC_RobotTask): task 0x11e49e8 has had a failure and has been stopped.
0x11e49e8 (FRC_RobotTask): fatal kernel task-level exception!
Unread 25-03-2012, 14:58
Re: Gyro code causes a crash
The gyro can only be used with the channels that have an accumulator assigned to them in FPGA. I believe this is currently channels 1 and 2 on slot 1 (I know Slot 1 channel 1, I believe the other is on slot 1 channel 2)
Unread 25-03-2012, 15:09
enrique's Avatar
awesome! that did it, thanks.
However, I got back 1784.183105
What is that suppose to be?
Unread 25-03-2012, 15:14
enrique's Avatar
It's working ok, not sure why I got that big value at first.
Unread 17-08-2012, 03:08
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
Probably because you didn't reset the accumulator right away.
Proud alum of CORE 2062.
www.core2062.com
