Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 25-03-2012, 15:41
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: US Digital E4P encoders and CIMple gear box
Originally Posted by swapnil94 View Post
Yeah I checked cad file and it is just like you said. Is there any way to attach those encoders on 5/16" shaft? Thanks
No. The E4P is not designed for shafts greater than .250".
There are three options to read the RPM on a 5/16" shaft:
  • link it to an idler wheel with a .250" output, and have the encoder read that
  • turn down the encoder end of the shaft to .250"
  • buy another encoder designed for 5/16" shaft
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
