Go to Post hmmm... big open space between arena and pits... thousands of poof balls...thousands of high school kids hopped up on sugar and robotics.... sounds a little dangerous. - Courtneyb1023 [more]
Unread 25-03-2012, 21:47
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
Re: 100% cpu and twitchy too
Just a quick recommendation, cheek the wireless in the area, The driver station says cpu is at 100% as a default when you loose the packets related to cpu level. If there are to many wirelesses on the same frequency, connection starts to suffer (yes, that is the reason for the no unnecessary wireless networks in competition area) and that can manifest as packet loss which can cause the cpu to show 100% and can also give you microscopically small loss of coms which results in a twitchy robot.
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 25-03-2012, 21:53
Actually, if packets are lost, CPU usage usually drops. This is true for the default LV framework, and I believe for C++ and Java too. If packets don't arrive, some parts of the system will run timed tasks, but other portions will stay asleep.
While it is possible for an excessive number of wifi networks to impact the connection to the robot, especially on 2.4 GHz, this will not cause CPU usage to rise on the robot. The charts tab will show whether the robot is losing comms, getting watchdogged, or running as prescribed. If you post a photo of the log file viewer, I can help point out the patterns.
Greg McKaskle
Unread 25-03-2012, 22:03
Peck's Avatar
Greg McKaskle
kk, i was speaking on what the software sub team told me to watch for when driving the robot at our regional. they may have altered something.
TEAM 1619
