Go to Post 4's company, 5's a crowd, and 6 is someone off-sides. - HyPhire111 [more]
Unread 23-03-2012, 21:23
theNerd's Avatar
theNerd theNerd is offline
FRC #3329 (Cam Bots)
Rookie Year: 2110
theNerd is an unknown quantity at this point
A work around for Linux users
I understand that Netbeans is available for Linux - and that it works swell for the robot programming. However, after learning that one can simply FTP files to the cRIO - which is what Netbeans does if I remember correctly - would it be possible to do the whole 9 yards through terminal? What I mean is:
1. writing the source code through VIM or another text editor
2. compiling the code (I'm not sure how far this can go due to my lack in knowledge with the WPILIB API releases and what Netbeans does exactly when it compiles the source code and creates the images)
3. FTP'ing the code to the cRIO.
If anyone could help explain the dirty details of what goes on in 2 and 3 I would be much obliged. Thanks awesome robotics community!
Unread 24-03-2012, 16:57
Scimor5 Scimor5 is offline
AKA: Brett
FRC #4520 (Misfit Toys)
Scimor5 is an unknown quantity at this point
Re: A work around for Linux users
compiling in a terminal is really easy. for c++ programs using g++ and its arguments correctly takes care of everything.
g++ -o myProgram thing.cpp main.cpp
This command compiles and links the code files
"thing.cpp" and "main.cpp" together into the executable program called
"myProgram".
other things to worry about are libraries
-I : Sets the path to the include files.
-L : Sets the path to the libraries.
-l : Use this library (eg. -lm to use libmath.so, -lpthread to use libpthread.so)
You can have multiple -I, -L and -l entries.
So, your final command should look like this:
g++ -o myProgram thing.cpp main.cpp -I /path/to/includes -L /path/to/libraries -l library1 -l library2
info about libraries can be found with the pkgconfig command.
Good luck from team 4520
Unread 24-03-2012, 18:25
frasnow's Avatar
frasnow frasnow is offline
Software
frasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to beholdfrasnow is a splendid one to behold
Sure it's possible, but why give up powerful tools like autocomplete, visible javadoc, Go to Source, tabs of code, quick access to the FIRST libraries, etc.? Some old time programmers consider those a crutch, but they're actually just wasting time doing things the slow way. Yes, I know some people think the command line makes you look cool, and it's probably a good learning exercise to make this happen. I still ask, why?
Unread 24-03-2012, 19:53
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
I have to agree with frasnow - Netbeans isn't a bug we have to "work around"! That said, you asked a fair question, and it deserves an answer.
Yes, it's absolutely possible. Start by downloading the Netbeans modules for FRC and extracting them. Everything you need to know is in there, you just have to find it.
To compile the code, you probably need to use Ant. This is what Netbeans uses under the hood, and all of the build processes are already written as Ant scripts. The goldmine is in FRCNetbeansUpdateV3077/edu-wpi-first-squawksdk/netbeans/modules/edu-wpi-first-squawksdk/ant.
As you said, Netbeans just FTPs the code to the cRIO. Basic details are on FIRSTForge. There's an Ant script that does the deploy, too, so that might be even easier than using FTP by itself. But we weren't asking about easy, were we? We're in this to learn... so hack on!
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 24-03-2012, 22:38
carrillo694's Avatar
carrillo694 carrillo694 is offline
Alex Carrillo
FRC #0694 (Stuypulse)
carrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the roughcarrillo694 is a jewel in the rough
theNerd did say he was using Vim -- plenty of plugins exist for autocompletion, going to source, etc., and tabbing comes built in
Vim can be configured to do all the NetBeans magic, and in a fraction of the time it takes to load NetBeans. But that doesn't mean it is easy, or that it makes development easier than NetBeans.
As StevenB notes, for Java we are already supplied with the build scripts (.xml files) -- we just have to use `ant` to properly. Incidentally, the build scripts are rather complicated. A mentor on my team created a visualization to describe the control flow (explained further here.) But you can also get a clue as to the fields from the .xml build scripts that are being invoked, and the order of their usage, by looking at NetBeans output when you Build your code. Brief statements, such as "flashapp:," "deploy:," etc. are printed to stdout as `ant` runs the .xml build scripts.
Also, to clarify, it's not the source code itself that you would FTP to the robot -- it's a .jar file generated from the `ant` build scripts that resides in the `suite` folder of your NetBeans project.
Unread 24-03-2012, 22:54
Alex Carrillo
Well, it seems this was 100 times easier than I thought it was!
For Java:
  1. Go to the root folder of your NetBeans project, where you should see a "build.xml"
  2. in the console, simply type `ant deploy` without the quotes
It's that easy! At least I think so; I need to try it in the lab on Monday. But it appears to be giving me the EXACT same output that the stdout console of NetBeans does after I tell it to Build the project!
Unread 25-03-2012, 20:04
theNerd's Avatar
Rookie Year: 2110
Well, for the "old timer" Linux community command line isn't just something that makes one look cool. GUI tends to a). take up loads of processing power that can be spent in better places. b). restrict the user command wise c). make things more complicated then it really is. Terminal (or command prompt for you Windowers) has proven to be extremely powerful. Granted it does take knowledge to use - that is it doesn't hold the users hand, but instead requires the user to have knowledge of his or her system, terminal allows the user to hold way more power over his/her computer than any GUI system. (There are tons of sites you could go to for this argument). For example in Linux when I install a program I can tell the computer EXACTLY how I want it to be set up, download it without going through a web-browser, where it install it, what to include and discard, how I want it to interact with other programs, and much much more. I can do all of this simply by typing in a line that is <20 characters long and wait less than 1 minute to install (including very large programs). On the other hand with Windows you have to download an installer, excute the installer, click a million times, wait forever and you still have very little control over the process.
As far as the IDE, its all preference. For most Netbeans and Eclipse are great, and along many lines it is. However, for Linux, we have what's called VIM. This is a SUPERPOWERFUL text editor that gives the programmer tons and tons of options and so forth. Personally I prefer to work with VIM more than Netbeans because my hands never have to leave the keyboard, and what would take simply a click and a drag now takes two keystrokes. VIM does have scripts for autocomplete and so forth which can put it along with Netbeans.
Now, I am sure that there are tons of valid points for both sides. However, that is not the point of this thread. Therefore, I must politely ask if we can stick to the question which is not why would we do it but can we?. Thanks.
Unread 25-03-2012, 20:07
theNerd's Avatar
Rookie Year: 2110
Could you send me the know how on how to do this? I've been trying to get my hands on how to do auto completion for any code (mainly c++ c and java), going to source, and possibly an equivalent to that error checking thing that Netbeans does.
Unread 25-03-2012, 20:09
theNerd's Avatar
Rookie Year: 2110
Are you referring to "the console" as the terminal/command prompt (I'm assuming the task is being completed on a Linux/Unix based system)?
Unread 25-03-2012, 20:16
theNerd's Avatar
Rookie Year: 2110
Talking Re: A work around for Linux users
"myProgram".
Haha! You have no idea how happy I am to have found a c++ person who knows about libraries . I used to be a Java programmer - still am - but now I would like to make c++ my core language seen that I'm going to need it a ton in college. Could you send me links to resources that greatly aided you in learning c++? and could I private message you with questions as I go through my learning curve?
Unread 25-03-2012, 20:19
Alex Carrillo
For good autocompletion:
http://www.vim.org/scripts/script.php?script_id=2540
For going to source:
http://www.vim.org/scripts/script.php?script_id=273
For more fancy IDE-style features for Vim (but I have not gotten this to work well for me):
http://eclim.org/
I have not yet found a good preprocessor to find errors before they happen in C++/Java, although I do have one for Python called python.vim.
Unread 25-03-2012, 20:22
Alex Carrillo
Yes.
Unread 25-03-2012, 23:09
AKA: Brett
sure you can PM me all you like. for the most part i learned by googling what i needed at the time. Lots of trial and error. the only specific resource i recommend is this http://www.amazon.com/C-Pocket-Refer...2730753&sr=8-3 it's purely an outline of every command and bit of syntax, no tutorials. its for when you remember your supposed to use something, but don't remember how to use it, or you know this command exists in java, and want to see how to use the c++ equivalent. c++ isn't very hard to learn especially if your coming from a different programming language.
Unread 26-03-2012, 00:21
Kevin Wang's Avatar
Kevin Wang Kevin Wang is offline
Software Engineer, Webmaster
FRC #0694 (StuyPulse)
Kevin Wang is an unknown quantity at this point
I put this together quickly to see what a terminal-based FRC IDE would look like. It's Vim and ant in tmux.
http://i42.tinypic.com/wjfa7b.png
Vim is running NERDtree on the left and the bottom window is zsh running 'ant deploy'.
Unread 28-03-2012, 19:33
theNerd's Avatar
Rookie Year: 2110
Wow! I like it! Would you guys happen to know where the wpilib is installed on a unix based system? ..... specifically Ubuntu
