Go to Post FIRST has stated time and again that the program is not about teaching (they always refer to the I and R in FIRST) - Dave Flowerday [more]
Unread 25-03-2012, 16:23
Clint Clint is offline
FRC #0308 (Monsters)
Clint is an unknown quantity at this point
Bug in WPILib PIDController?
The following code excerpt is found in PIDController.cpp of revision 3111 of WPILib, on lines 128 through 141.
double potentialIGain = (m_totalError + m_error) * m_I;
if (potentialIGain < m_maximumOutput)
	if (potentialIGain > m_minimumOutput)
		m_totalError += m_error;
	else
		m_totalError = m_minimumOutput / m_I;
else
	m_totalError = m_maximumOutput / m_I;
m_result = m_P * m_error + m_I * m_totalError + m_D * (m_error - m_prevError);
In the lines of code above, a subtle problem exists, under a certain few specific conditions:
  • Output is restricted with a minimum or maximum of 0
  • m_I is 0
Under these instances, the first if statement fails (or, it continues through to the second inner statement which also fails). In both cases, the total error is calculated by dividing by m_I. When m_I is zero--a perfectly logical use case--m_totalError becomes NaN.
As a result, m_result becomes NaN as well. Subsequently, when PIDController::Calculate writes this value to the output, errors rapidly accumulate in the console.
Clint
Unread 26-03-2012, 11:41
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: Bug in WPILib PIDController?
You should file a bug at the WPILib tracker.
http://firstforge.wpi.edu/sf/tracker....wpilib_c_bugs
Unread 26-03-2012, 19:32
Thanks. If anyone else is interested in following this issue, the artifact can be found here.
