Go to Post "If two kids from every school who would otherwise have been uninterested in technology watched this special tonight and was inspired to learn more, then the world just changed because of it." - Barry Bonzack [more]
Unread 26-03-2012, 21:35
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Problems with 2011 Retro Sensors
We are using the 2011 Retro-reflective Sensors this year to sense our wheel rotations. We spent a lot of time debugging them and we have determined that if our voltage drops below 10 volts, the sensors will bugg-out and add in extra counts. We temporarily fixed this problem by wiring the power from these senors to the 24 volt power supply on the board. Does anyone have any suggestions on how to supply a better voltage to these sensors without using the 24 volt hookups from the PD board?
Unread 26-03-2012, 21:41
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Problems with 2011 Retro Sensors
You can run the same cRIO 24V from the PDB to a Solenoid Bumper on your cRIO, and then power your sensors from the Solenoid Bumper. You would "turn on a solenoid" and it would supply 24V to your sensor.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 26-03-2012, 21:48
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
What Mr. Lim said. This is a GDC sanctified method of powering those sensors.
If you can't do that for some reason, you might try to find yourself a 12V to 24V DC-DC converter. Just check the specs on it and make sure it's good down to 7V or so, or you'll just blackout your converter and then your sensors.
