Go to Post Some call those dreams- others nightmares - Wayne C. [more]
Unread 26-03-2012, 23:35
Tanaythan's Avatar
Tanaythan Tanaythan is offline
Programmer
AKA: Tanay Nathan
FRC #3256 (Warriorborgs)
Tanaythan is an unknown quantity at this point
Arcade Drive with Speed PID?
Hi all,
My team has decided that we want to use Speed PID because they think it will be better for fine tuning on the bridge. However, the only problem I see with it is that we have to use Arcade Drive because our driver prefers it over anything else. We use the CAN Speed settings on our jaguars to indicate our velocity and we are wondering if we can use RobotDrive with the Speed PID. Note we are also using Master/ Slave mode. Do we have to come up with our own algorithm to do Arcade Drive in master slave mode or can we just use some of the Robot Drive functions given to us?
Tanay Nathan
Programmer
Team #3256 Warriorborgs
Unread 04-04-2012, 12:45
Tommy.Brown's Avatar
Tommy.Brown Tommy.Brown is offline
Lead Programmer
FRC #1477 (Texas Torque)
Tommy.Brown is an unknown quantity at this point
Re: Arcade Drive with Speed PID?
From my experience, it will be most effective in the long run to completely create your own form of the drive code, it can still take in the inputs from the joysticks as Arcade Drive does, however you can take the values and figure out a PID setpoint and run the PID algorithm to calculate your motor speeds.
Joystick->PID->SpeedController
If you need any help with any of this I am very experienced with writing custom drive codes for robots, feel free to send me a message if you need help...
FRC Team 1477 - Texas Torque
The Woodlands, Texas
Unread 04-04-2012, 13:16
C pseudocode for arcade
Unread 05-04-2012, 15:17
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Originally Posted by rawrxp View Post
Hi all,
By Speed PID, do you mean using the CAN Jaguar kSpeed control mode? If so, you should be able to use RobotDrive::ArcadeDrive with speed control mode. According to the code, you should be able to call RobotDrive::SetMaxOutput to set the maximum speed of your robot and then just feed RobotDrive::ArcadeDrive with your joystick values that's in the range of -1.0 to 1.0, the SetLeftRightMotorOutputs() code in RobotDrive will scale your -1.0 to 1.0 range to your -maxOutput to maxOutput range which is your speed range.
Unread 05-04-2012, 16:45
If no rotation is being commanded and the vehicle is traveling in a straight line, you could do that.
Otherwise, it wouldn't work very well.
The input commands to an arcade algorithm are vehicle forward speed and vehicle rotational speed.
The arcade algorithm performs a reverse kinematic calculation on those commands to determine the necessary left and right wheel speeds to give the commanded vehicle motion.
The signals from the 2 wheel encoders are left and right wheel speed.
In order to obtain a usable process variable to do what you have suggested, you would have to reverse-engineer the PID's reverse kinematic calculation to obtain a forward kinematic calculation, which you would then apply to the encoder signals to obtain estimated vehicle forward speed which could be used as a process variable.
It would probably be a lot easier and cleaner to just write your own arcade code, and close the loop on left and right wheel speeds directly.
Unread 05-04-2012, 18:32
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
Ether,
Your website link didn't work for me last time nor this time. Any thoughts? Anyone else unable to click to those links?
bob
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
Unread 05-04-2012, 18:51
Originally Posted by bob.wolff68 View Post
Ether,
bob
Thanks for letting me know.
I just added a "www" to the link. Let me know if that fixes it.
If not, I'll find a different web host.
Unread 05-04-2012, 20:16
Da' Mentor Man
FRC #1967
No go. Didn't help. :-(
bob
Unread 05-04-2012, 22:03
bob
OK, I uploaded to CD media:
http://www.chiefdelphi.com/media/papers/2661
