Thread Tools |
Rating:
Display Modes |
Re: Week 4 OPR - All regionals and districts
Together, these 25 teams account for 51 spots in the top 100. |
6 of the top 30 OPR performances of the season have been produced by Canadian teams.
All but one of those Canadian teams has qualified for STL, with only 3161 being on the outside looking in. 3161 was also the team which had a chance to snatch the #1 seed away from 1114 in their last match at Waterloo. They held the tiebreaker over 1114 with a higher Hybrid Points total. This is the match where it all happened, and also contains a "triple double" with all 6 robots balanced... http://youtu.be/uIdpZvfJDnE |
Team Rank 1 Rank 2 Rank 3 Average 67 1 2 1.5 2056 3 7 5 341 4 6 9 6.333333333 1983 5 16 10.5 1507 12 17 14.5 1114 14 22 18 1986 13 36 24.5 2474 10 46 28 469 19 39 29 48 28 43 35.5 16 38 42 40 1218 40 41 40.5 2169 27 56 41.5 1477 25 63 44 365 11 82 46.5 399 44 57 50.5 488 29 72 50.5 1629 24 79 51.5 340 45 59 52 610 30 93 61.5 1714 53 70 61.5 2826 52 74 63 148 73 75 74 967 66 95 80.5 1208 87 88 87.5 |
The only issue with using the average OPR is that is disregards changes made between competitions and leads to an inacurate ranking. I think ranking the OPR's from teams leatest event is a more accurate way to rank teams via OPR because it represents what teams are doing currently not in week 1 or 2. An example of this is 365, in week 2 at chestnut hill district they had an OPR of 21.2 ranking 82nd over all while week 4 at Lenape with a new shooter 365 had an OPR of 31.1 ranking 11th or using teams latest event's OPR ranking 7th.
P.S. I really like the new shooter ![]() |
#7
I in no way want to demean any particular tournament. St. Louis is a great regional -- well-run and in a nice facility. The teams there were all fantastic; it's just that there were a higher percentge of teams that couldn't score. |
#8
This is partially true. Your team's OPR is the least-squares approximation of how many points your robot can score in a match, which is based both on the number of points each of your alliances scores, and who was on each alliance. This basically means that if you're always on high-scoring alliances, you'll probably have a reasonably good OPR, but your OPR will be higher if your partners have lower OPRs and vice versa. (I can give a more detailed mathematical explanation of how OPR works if you like, but I think that post has probably been made already somewhere around here.)
#9
WI regional standouts (condensed from OP data):
OPRNice to see a high level of competition in the Miltown! |
#10
I usually take CCWM with skepticism, unless I'm looking for a defensive team or strategic specialist. I've seen instances that strength of opponents really impacts CCWM, but doesn't have much affect on OPR (unless it's a highly defensive game). In other words, if you play a tough schedule and lose all of your matches 85-80, your CCWM will suffer because of the number of losses. The OPR will show that you can put up a lot of points and the losses aren't likely your fault.
