Go to Post No need to apologize, you didn't do anything wrong. your just learning. thats what the forums are for. please keep them coming. - Tytus Gerrish [more]
Unread 27-03-2012, 02:51
ablahblah ablahblah is offline
The Blaghh!
AKA: Alex
FRC #4404 (The Nuts 'N Colts)
ablahblah is an unknown quantity at this point
Pneumatic robot lifts allowed?
Well, its a bit late but I just had this random, interesting idea for drivetrain building; no idea if it's legal though. My team just ran a kiwi omnidrive, which worked beautifully IMHO with correct load balancing (Our last 3 games, we had no practice with the properly setup drivetrain). Meh, I know we could have bridged too with that, just had no practice.
Anyways, what I was thinking was adding a fourth wheel (or duo), traction type, in the center of the bot. It would be raised/lowered by a pneumatic piston connected to the front bumper (ideally jutting out a bit from the main frame structure, via frame perimeter extension sitting on top). The idea is that omni drives inherently can't push as hard as tank; this would enable tank drive on that platform with two powered rear wheels by just putting them down with the piston to a set distance via reed switch to engage them. Specifically with pushing, you could hyperextend the piston when holding ground. What I believe theoretically happens is they apply pressure to the angled piston when pushing it, which just forces the traction wheels more into the ground to make their push harder. Only drawback is you might have the bumper jacked up a bit at times, and I dunno, is that legal (assyme the bumper height is not exceeding the bumper zone)? Technically you do still have a wheel in contact with the ground, not just a stick.
Unread 27-03-2012, 05:47
Lavapicker's Avatar
Lavapicker Lavapicker is offline
FRC #1056 (Hot Rocks)
Lavapicker is just really niceLavapicker is just really niceLavapicker is just really niceLavapicker is just really nice
Re: Pneumatic robot lifts allowed?
We used two cylinders to pneumatically lift our robot up about 15 inches to land on top of and drop the bridge this past weekend in Hawaii. The cylinders pushed a wheelie bar capped with wood ends from the bottom of our frame. It pivoted from just behind the front bumper. One of the latest updates allow you to temporarily violate the bumber zone to cross the bump or to get on a bridge. These were the only two exceptions and we were warned not to wheelie too far from the bridge to avoid a penalty. We thought of using it on the bridge to drive up onto a partner but I don't think that would be legal under the exceptions made in the update. You can always run it by the head ref in practice. BTW, it worked like a charm everytime!
2003 - Pacific Northwest Regional-Seattle :Quarterfinalist
2004 - Pacific Northwest Regional -Oregon
2007 - Silicon Valley Regional
2007 - Atlanta:Galileo Field (5-2)
2008 - SVR finalist*, Engineering Inspiration Award
2008 - Hawaii semi-finalist, Team Spirit Award
2008 - Atlanta:Archimedes (3-3-1)
2010 - Hawaii regional quarterfinalist
2011 - Hawaii regional finalist, Engineering Inspiration, Innovation in control
2011- St. Louis Galileo Field (7-3) 14th seed, quarterfinalist
2012 - Hawaii Regional Semi-finalist, creativity, industrial design awards
Unread 27-03-2012, 07:45
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Perfectly legal. You may want to look into this video of Team 148's 2010 Robot. It had something like you described but was not a kiwi omni drive.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 27-03-2012, 08:23
FRC #1836 (MilkenKnights)
Yes, this is a perfectly legal method of a drive system. You can see very good implementationson both 148's and 217's bots from 2010, of a slightly different drivetrain, where all the wheels pivot down, the sides pivoting down onto treads, and the center wheels being pivoting omnis. While it is very maneuverable yet still being able to push other robots, it is slightly complicated and it does use many motors.
Unread 27-03-2012, 08:58
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
While not quite on the scale you're looking for, you can also see this type of acuation on 1625's Logomotion robot, with their side moving 10 wheel lobster drive, in which they are a standard 6 wheel drive, but then also have 4 perpendicular wheels (2 front and 2 back) which come down and lift their 6 wheels off the ground so they can translate sideways.
Academic Student (Forever)
Unread 27-03-2012, 09:43
MountainFreak MountainFreak is offline
FRC #1629 (Garrett Coalition (a.k.a. GaCo))
MountainFreak is an unknown quantity at this point
Does anyone know what kind of drive train that was that 148 was using? like what is it called?
GO GaCo!!!
Unread 27-03-2012, 09:48
148/217 was using nona drive in 2010
Unread 28-03-2012, 11:09
kellymc kellymc is offline
FRC #0766 (Bears)
kellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to behold
I'll get some photos this weekend of our robot, we have a 6 wheel drive, where the center wheels are mounted on pneumatic cylinders to retract the wheels when crossing the bump and balancing on the bridge.
Kelly
Unread 28-03-2012, 16:48
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
In 2010 my team used pneumatics to lift the robot when crossing the bump. You can see it here:
http://www.chiefdelphi.com/media/photos/35746
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 29-03-2012, 01:19
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Alternatives you may want to look around CD for are octacanum (Madison's made a lot of great posts detailing how you can make one) and jump drive (a.k.a. jester drive).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
