Go to Post If your logo is your team number in a font 4" tall in 1/2" stroke, colored/outlined in white, then yes. Otherwise, no. - cadandcookies [more]
Unread 07-01-2003, 14:11
Matchew Matchew is offline
Matchew is an unknown quantity at this point
Send a message via AIM to Matchew
Gyro help
DOes anyone know how to program or have any tips on how to use the gyro???
Unread 07-01-2003, 14:14
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
I'd recommend posting this in the programming forum.
Other than that, i know that they are pretty tricky to use.
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 07-01-2003, 14:24
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
This also falls under the
search before you post umbrella. I know questions like this have been asked multiple times.
If you still can't find it after searching, PM me and I'll send you stuff.
Unread 07-01-2003, 15:30
wwrye wwrye is offline
#0057 (Leopards)
wwrye is an unknown quantity at this point
What exactly are you trying to do with it?
Unread 07-01-2003, 18:30
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
gyro
Hook the gyro up to the analog inputs. In the control manual, it should tell you how. Assign it to one of the analog inputs, ex: analog3, in default code, sensor3. Turn the constant for sensor3 on, add it to your serin command, and input data from it. The yaw rate sensor, measures the rate of angular change from an arbitrary plane. So basically in the right position, if you turn it, the value changes. However, it resets starts recounting after around 60ms (3 pulses). This might help, heres our default code, it has some balancing code using gyros for the eduRobot.
Gyro Code -> sub_balance
R
Unread 07-01-2003, 18:36
Actually, the the yaw rate sensor measures the rate of angular change. This is why if you stop moving it, it goes back to neutral. If you turn it faster, the larger (or smaller) the value will be.
Unread 11-01-2003, 09:10
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
Lets see, angular turning rate integrated with time gives us an angle. This may not work well in PBasic but think of what could be done in the "Black Box"
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 20-01-2003, 10:49
Morgoth Morgoth is offline
#0471 (Cybertigers)
Morgoth is an unknown quantity at this point
Isn't THIS the programming forum. LOL
"Lock the Doors"
NASA chief flight director Leroy Cain on the loss of Columbia's signal.
gyro code odin892 Programming 2 08-04-2003 14:50
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
Is any team using the gyro chip? Ragin_Kage Kit & Additional Hardware 4 10-04-2002 12:11
Voodoo Gyro Chips... Ghetto_Child Technical Discussion 3 01-02-2002 16:39
Have YOU used the gyro chip? FotoPlasma Technical Discussion 10 31-01-2002 13:26
