Go to Post the political parties should consist of AndyMarkcrats and IFI-icans.... - Josh Hambright [more]
Unread 27-03-2012, 09:17
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
Re: Colson 101
Originally Posted by SuperNerd256 View Post
So on a standard 27x54 flat carpet field, what advantages will Colsons give over regular treaded wheel?
Everything is an engineering trade off in some way, wheel selection is no different. "Absolute Advantage" is subjective.
Pros that we've found for the Colson Performa wheels:
- Low Cost
- Never change tread
- Approximately match Roughtop on Carpet (un-grooved)
- Outperform on other surfaces (Plexi, HDPE, diamond plate)
- Some Shock Absorbing capability
- They "warm up" during a match (gearheads may find this interesting)
- COTS dead axle hubs available (this was previously the barrier to entry for most teams)
You can get CAD Models from the Colson Website. You may have to download the entire caster then save just the wheels, this is typically what we have done. I do have a model for the 4"x1.5" on my home computer if needed.
Unread 27-03-2012, 09:25
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Colson 101
Originally Posted by Josh Drake View Post
Has anyone tried a Colson on a swerve module?
Team 228's 2010 Swerve Used 'Cut' Colsons, Team 148's 2008 swerve used Colsons, Along with 3928 (2012) and Team 40 (2011) as already mentioned.
Originally Posted by jwfoss View Post
*snip*
*snip*
In a simple pushing test in the pre-season (I sat on carpet, had the drive push against my feet for ~15 seconds) I found that the wheel temperature got to ~100-105* F depending on which drive wheel it was (30* increase from room temperature of ~70*). There was a noticeable improvement in performance immediately following this test, almost as if the drive had more 'bite' on the carpet.
-Dustin Benedict
Jared Russell's Avatar
Taking a year (mostly) off
Re: Colson 101
Is there a source for COTS live axle Colson hubs? Not that these are terrible difficult to make, just wondering.
Unread 27-03-2012, 09:44
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Colson 101
No COTS source yet. I believe RC will be offering them in the future.
2415 has used colsons for the past 2 years as well. Last year we swapped to them after using custom treaded wheels and the increase in performance was noticeable. This year we strayed to pneumatic wheels to deal with the bump and were incredibly disappointed with the performance. We have just finished swapping to colsons for a weight savings of 2.5lbs and again the increase in performance is night and day. We will not be using any other wheels in the future.
Mentor 2415
Unread 27-03-2012, 10:14
JakeD's Avatar
JakeD JakeD is offline
FRC #0360 (The Revolution)
JakeD will become famous soon enoughJakeD will become famous soon enough
Re: Colson 101
All my experience has been with the standard KOP wheels, as well as the andy mark Plaction wheels with both rough and wedge top. I've always found the wedge top to out preform on HDPE and other non carpeted materials but the rough top to maintain traction better on carpet. It seems to be relatively widely noticed that the Colson wheels out preform the rough top on HDPE and has similar performance on carpet but has anyone compared them to the wedge top?
Unread 27-03-2012, 10:15
AKA: Sean
Re: Colson 101
Colsons stick much better than roughtop or wedgetop to anything other than carpet.
Mentor 2415
Unread 27-03-2012, 10:32
Brandon Holley's Avatar
Re: Colson 101
Rougtop and Wedgetop are extremely similar because they are made from all the same materials (either nitrile or natural rubber). The geometry of the tread pattern does create slightly different performance characteristics, but compared to different wheel types (pneumatic, colson, etc) the differences are huge.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 27-03-2012, 11:24
AKA: Justin Foss
Re: Colson 101
If you are local and interested in checking out both the dead axle hub or a hex live axle plug, FRC2168 always has spares to show to other teams (and judges).
We've already competed at NYC, and will be at the CT regional in a couple days. Feel free to stop by.
There are also a bunch of pictures on our teams website and on my personal/robotics blog.
Unread 27-03-2012, 11:53
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Colson 101
3620 used 8" Colson Performa wheels with the WCP hub this year. It required an outboard bearing adapter, but that was easy to make out of Delrin.
Look here for pictures.
Richard Wallace
since 2003
Unread 27-03-2012, 12:15
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Re: Colson 101
Robot Marketplace also sells colsons with a sprocket and bearing pressed into them. http://www.robotmarketplace.com/prod...it_wheels.html
Unread 27-03-2012, 12:21
AdamHeard's Avatar
Lead Mentor
Re: Colson 101
I've heard rumors and claims over the year over the actual numbers and how high they are (for traction), but have yet to see anyone do real testing and post.
Anyone done it?
Unread 27-03-2012, 12:33
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: Colson 101
If you like Colson, but don't want to bother with separate hub manufacturing or purchase, check out NPC wheels which have very similar characteristics and have hub included:
http://www.robotmarketplace.com/prod...lrin_hubs.html
1712 used NPC wheels in its drivetrain in 2006, 2007, 2008, and 2010. During those years the wheels performed very well on all kinds of surfaces, including those similar to what is being used this year, and in all kinds of configurations (4-wheel, 6-wheel, wide-body, long-body).
As pointed out you will expend a little weight here, but when I was in a decision-making position, I always thought it was weight well spent for a wheel that will last, get around, help you score, and stand up to playing aggressive defense when/if a game or strategy calls for it. I'm also sure there are plenty of places you could take some mass out of the wheels if you wanted/needed to as well.
And while we never grooved the NPC wheels to improve traction on a competition robot, I'm well aware of the success Brando and others have had with this technique and did like what I saw with some off-season lab testing several years back.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 27-03-2012, 12:37
AKA: Sean
Re: Colson 101
For what its worth, the NPC wheels are colson wheels just with a delrin hub inserted. If you dont have the machining resources theyre great; however, if you have access to a lathe it is much more economical to do a simple plug. This gives you the option of hex broaching as well so you dont have to deal with keyways.
Mentor 2415
Unread 27-03-2012, 12:43
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Colson 101
We used them on our shooter this year, as well. We opted for KoP wheels (then later two omnis on one side) for our drive train for weight and size constraints. We may change that in the future.
Unread 27-03-2012, 12:48
Re: Colson 101
Agreed on the cost if you're into those manufacturing techniques.
