Go to Post My code mentors once told me, "A good programmer can look at a library, decide he hates it, and code everything from scratch. An amazing programmer can look at a library, decide he hates it, but realize the time it will save him and learn to use it." - slavik262 [more]
Unread 07-01-2003, 18:30
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Tokenizer Whitepaper Help
Here's the code I typed into a Win32 Application (not console):
HANDLE myLib = LoadLibrary("tokenizer.dll");
CompileProc Compile;
VerifyProc  TestRecAlignment;
VersionProc Version;
TModuleRec	tModRec;
Compile =          (CompileProc)GetProcAddress(myLib, "Compile");
	Version =		   (VersionProc)GetProcAddress(myLib, "Version");
	TestRecAlignment = (VerifyProc)GetProcAddress(myLib, "TestRecAlignment");
And here's the errors I get:
C:\Program Files\Microsoft Visual Studio\MyProjects\RoboCode\RoboCode.cpp(14) : error C2664: 'GetProcAddress' : cannot convert parameter 1 from 'void *' to 'struct HINSTANCE__ *'
        Conversion from 'void*' to pointer to non-'void' requires an explicit cast
C:\Program Files\Microsoft Visual Studio\MyProjects\RoboCode\RoboCode.cpp(15) : error C2664: 'GetProcAddress' : cannot convert parameter 1 from 'void *' to 'struct HINSTANCE__ *'
C:\Program Files\Microsoft Visual Studio\MyProjects\RoboCode\RoboCode.cpp(16) : error C2664: 'GetProcAddress' : cannot convert parameter 1 from 'void *' to 'struct HINSTANCE__ *'
The code compiled perfect when I did it in a console program, and all I did was copy/paste it (the code is in the "WinMain" thing). I've tried to fix it, but no luck, and I've looked up the errors on MSDN, but it didn't help me at all. Can someone help me please? The tokenizer.dll is in the folder where it's supposed to be (it loads correctly). I'm using MSVC++ 6.0 incase that helps at all.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 07-01-2003, 19:01
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Sorry, that's my fault. Instead of declaring myLib as type HANDLE, make it HINSTANCE. Sorry for the confusion.
Unread 07-01-2003, 19:03
AKA: Eric Hansen
Ok, thank you...It's alright, I knew it was probably that though, but 1 question...why did it when without doing that in a console program?
Y!: synsoflife
Unread 07-01-2003, 19:23
It's possible that your Console app was setup to use C, whereas your new one is set for C++. Someone correct me if I'm wrong (which I probably am), but I'm guessing that the C compiler will convert pointer data types without even asking. After all, a pointer is just a pointer until you try to dereference it...
Unread 07-01-2003, 19:26
AKA: Eric Hansen
I'm not sure (I don't work with pointers alot), but you might be right. I don't think pointers work to well in C though (which goes along with my first statement). Is all your programs in MFC?
Y!: synsoflife
Unread 07-01-2003, 19:55
Mongoose's Avatar
Mongoose Mongoose is offline
#0948 (Newport Robotics Group (NRG 948))
Mongoose is an unknown quantity at this point
Send a message via AIM to Mongoose
I, too, might be wrong, but I believe C is more lax with pointers than C++. I know C++ *requires* you to type cast void pointers. (Perhaps that's why C is a better language for writing exploits?)
I never knew HANDLE was #define'd or typedef'd as a void*, which certainly adds to the confusion.
Unread 07-01-2003, 20:43
rwaliany's Avatar
rwaliany rwaliany is offline
R
None #0691 (HartBurn)
rwaliany will become famous soon enough
yeah
Microsoft tends to add BS additions to their windows gui to make it look hard and make themselves look original.
LPCSTR
isnt that like
const char*
I prefer const char*, I dont know about you.
R
Unread 07-01-2003, 20:52
Re: yeah
LPCSTR
isnt that like
const char*
Take out the const and you're right. LPCSTR is never meant to be used by itself; you are always supposed to use LPCTSTR, so that code will automatically work under either Unicode or Ansi.
Also, using typedef in cases like this adds another layer of abstraction, which is a "good thing" from a software engineering view. Because this is translated directly into char * at compile-time, it's also one of the few abstractions that doesn't detract from performance.
That said, I never touched the MS-specific ones, except when dealing with MFC/API functions, while writing either RoboGUI or RoboEmu. Both use char * and I wouldn't have it any other way.
Unread 08-01-2003, 14:23
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
rbayer is right... Microsoft uses a LOT of macros and typedefs to abstract the data types, which is a GOOD thing.
If you look at the declarations, they are usually in some sort of #ifdef condition, so that by simply adding or removing a symbol from the preprocessor, your program can use different data types without changing any code. This is very useful if you want to be able to build your project with Unicode support.
Unread 08-01-2003, 16:21
rwaliany's Avatar
R
Microsoft
Still, but why use LPCTSTR, instead of like mStr, well I guess they do that for MFC. I would still rather do my own unicode support. I haven't found any good documentation with the prototypes for windows GUI and the defines such as HANDLE HINSTANCE. I've been stuck reading their header files. I like Linux GTK better, its so much more common sense to me.
I suppose that is because it takes 5-7 lines to add a toolbar to a window in GTK and 25-30+ in MSVC++ (NON MFC).
R
Unread 08-01-2003, 16:25
AKA: Eric Hansen
you can do something like:
#define NewName LPSTR
Y!: synsoflife
Unread 09-01-2003, 13:24
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
You're absolutely right in that C doesn't have much in the way of type-safety. Most of the WinAPI weird data types are #define'd void*'s or various species of int's. I use some of them and not others... just whatever fits the bill.
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
Unread 09-01-2003, 18:28
AKA: Eric Hansen
The only thing I've found you can't use #define on is the comment (I wish I could though), and stuff like void, but I've not tried all of them.
Y!: synsoflife
Documentation / Whitepaper Ideas. Josh Hambright General Forum 2 18-05-2003 17:15
Tokenizer Confusion Raven_Writer Programming 2 05-01-2003 16:23
How to use the PBASIC tokenizer rbayer Programming 0 12-12-2002 12:56
PBASIC Tokenizer Neal Probert Programming 9 28-10-2002 19:12
Edit whitepaper rbayer CD Forum Support 5 03-10-2002 18:11
