Re: pic: FRC971 Spartan Robotics Presents: Renegade
Take a look at this short video http://www.youtube.com/watch?v=5aYv5RF2Arg Last edited by roystur44 : 27-03-2012 at 14:56. |
Man, Renegade looks better and better by the video. That's some of the fastest 3 point shooting I've seen. I'm hoping we get to play with 971 in a few of our matches at SVR. I can see this robot going right to the top.
![]() Great robot! Last edited by Jared Russell : 27-03-2012 at 15:01. |
Hmmm, 4:57 and 6:04 were pretty unexpected, but I guess they are unveiling week 5 anyways. Looks like a narrow robot with a pretty slick over the bumper collector and a high shooter (probably turreted) Sweet..
Edit: narrow because the fender sticks out 38ish inches. Last edited by BJC : 27-03-2012 at 15:40. |
How do you get that from the video? I've watched those segments about 20 times myself, and though I see bits of it, I can't tell too much from it.
Yes, Yes, No.
#7
Not turreted? well I suspect you wouldn't really need it anyways (If that is indeed what you are saying no to.) Good luck at your first competition this year.
Regards, Bryan Last edited by BJC : 27-03-2012 at 22:29. |
#8
Here's a little video of practice for Champs:
Shooting practice: http://www.youtube.com/watch?v=kTVE8c_mgoI Behind the glass: http://www.youtube.com/watch?v=p32DlVbJpFw |
#9
That was one of our best runs, but we have been hitting 90%+ over the past few days. There is also no camera tracking running in that video, that's pure video feedback to the driver station, and Scott doing what he does best. There may be camera tracking in St. Louis, which could further reduce the cycle time.
#11
Awesome shooting! How do you like the steering wheel for driving control? And is it just the wheel or are the other buttons/pedals/something involved?
#12
1. A wheel (you can also use the X axis of a joystick) for turning 2. A throttle 3. A quick turn button When you are not holding down the quick turn button, the wheel and throttle let you control the bot like a car (in other words, constant radius turns independent of your throttle power, which is hard to do with arcade or tank setups). When you hold down quick turn, you can turn in place (the wheel becomes like a standard X axis in an arcade drive). But again, just a guess ![]() |
#13
Same question. To add on, do you feel there are any advantages to using the steering wheel controller? (User intuitiveness, just feels easier/right to use, etc?)
#14
Austin can give a more accurate answer than I, but I believe we are running a version of "Cheesy Drive"
At high speeds, your rate of turn is very sensitive to small disturbances in drive side speeds, so holding a good line with tank sticks gets increasingly difficult as your drive speed goes up. By letting the computer take care of the exact speeds and feeding the system a turning radius and speed, high speed control becomes much easier. It also allows you to scale the steering response based on your throttle level, although I don't know if we do that or not. The quick-turn button allows a more traditional steering scheme for in-place turns. We've been using a steering wheel setup since 2006 and it's served us really well. It's just the wheel and a joystick for throttle control, as Jared surmised. |
#15
Thanks. Just for reference, do you know which steering wheel controller you use?
