Go to Post I'm looking foward to the challenge! - Adrienne E. [more]
Unread 27-03-2012, 15:35
Re: Adjust individual motor speed
Originally Posted by Butter's View Post
Our robot has a slight curve so I wanted to make one robot [ed: motor?] have a little more power than the other
First and foremost, you want to determine if there is an alignment or friction problem in your drivetrain, or a resistance problem in your wiring, that is causing this. For example, see this post. If you find a problem, it is far better to correct it at the source.
Secondly, What kind of drivetrain do you have, and what is your driver interface? I ask because there may be better ways to compensate.
Unread 27-03-2012, 15:42
Butter's Butter's is offline
AKA: Joe Kent
FRC #0522 (Robo Wizards)
Butter's is an unknown quantity at this point
I probably could answer your questions, however, I would rather talk to one of the team members on the build committee first before I throw out possibly incorrect information.
