Go to Post Ask two different FIRSTers for an opinion, get three different answers! - pfreivald [more]
Unread 27-03-2012, 15:16
ss9090 ss9090 is offline
AKA: Stewart Smith
FRC #4367 (Streetbots)
ss9090 is an unknown quantity at this point
cRIO FRC_RobotTask error
Hey guys. I don't have much time before my competition and I just got this error from the NetConsole;
0x28bffe8 (FRC_RobotTask): task 0x28bffe8 has had a failure and has stopped.
A search brings up no hits. Does anybody have any idea about what causes this task error and what I can do to solve this?
Will post code if necessary.
Quick replies would be lovely.
EDIT:
Got rid of my Initial error by fixing up my pointers, however I now get a new error upon clicking 'Enable' on the driver station:
0x28c00e0 (FRC_RobotTask): task 0x28c00e0 has had a failure and has stopped.
0x28c00e0 (FRC_RobotTask): fatal kernel task-level exception!
Again, help is much appreciated.
FRC 4736 Streetbots
2012 Streetsville Secondary's pioneering FRC team
Thanks to our mentor team, 1241 Theory6, for all of their help! I wish everybody there the best in their futures.
-Lead Programmer (Wind River C++)
-Lead Electrical
-Lead Controls
-Part-time Build
2012 - 17th seed (GTR West)
Unread 27-03-2012, 15:29
Bharat Nain's Avatar
Re: cRIO FRC_RobotTask error
I saw an issue in Orlando where we were trying to gather input from the Analog Input on the DS Software. Sometimes, it returned a null and caused a null-pointer exception. I can't say if that is your issue but it is possible. Thanks to Andrew Schreiber for helping me track that bug down.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 27-03-2012, 15:43
AKA: Stewart Smith
Thanks Bharat. I'm currently going through looking for a similar issue. Figured it must be a an improper pointer assignment, so I'm scouring through the lines hehe. Glad to know I'm on the right track.
FRC 4736 Streetbots
-Lead Electrical
-Lead Controls
-Part-time Build
Unread 27-03-2012, 19:59
bob.wolff68's Avatar
bob.wolff68 bob.wolff68 is offline
Da' Mentor Man
FRC #1967
bob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nicebob.wolff68 is just really nice
I agree - most likely the use of a null pointer. As a general rule of C/C++ programming, this is a MUST -- check all pointers before using them. **ALSO** if you 'delete' a pointer, set that pointer to NULL afterwards as well. The programming is a little more 'verbose', but it is SAFER. Crashing in a real-time robot is the PITS.
For instance: (Writing a sample that should be rather 'real' but is from memory so may come with issues...this is intended to show the use of pointer checking -- not syntax and running code)
ColorImage* pImage;
pImage = NULL;
AxisCamera& cam=AxisCamera::GetInstance();
BinaryImage* pBin;
pBin = NULL;
while(IsOperatorControl())
  if (cam.IsFreshImage())
    pImage = cam.GetImage();
    if (pImage)
      pBin = pImage->ThresholdHSL(x,y,z,zz,p,d,NULL);
      if (pBin)
        // Do something using pBin like particle report ...
      else
        printf("ERROR: ThresholdHSL() failed.\n");
    else
      printf("ERROR: GetImage() failed.\n");
    // Done with the image -- must dispose of it.
    // But *SHOULD* also reset it to NULL so it doesn't get used accidentally.
    if (pImage)
      delete pImage;
      pImage = NULL;
    if (pBin)
      delete pBin;
      pBin = NULL;
Bob Wolff - Software from the old-school
Mentor / C / C++ guy
Team 1967 - The Janksters - San Jose, CA
