Go to Post I even have a t-shirt that says "Actually, I -am- a rocket scientist" :) - dlavery [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 27-03-2012, 18:26
adamdb adamdb is offline
adamdb has a spectacular aura aboutadamdb has a spectacular aura aboutadamdb has a spectacular aura about
Target illumination LEDs - What color? How bright?
For those using LEDs with the Axis camera to illuminate the target, what color works best and how bright do they have to be? A quick perusal of Ebay shows a wide range of colors with brightnesses from 5000mcd to 20000mcd. Do some colors work better than others? Would twenty 5000mcd LEDs work as well as ten 10000mcd LEDs? Do we even need the LEDs? I have seen some teams using the Axis camera without them.
For those that are using LEDs, did you buy a pre-made widget with the LEDs already on it or build your own from individual LEDs? How many LEDs or what total brightness should we be looking for?
Just looking for some data, anecdotal or measured.
Thanks
Adam Bryant
Programming Mentor
Team 1583
Ridge View Academy Rambotics
Unread 29-03-2012, 21:25
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Target illumination LEDs - What color? How bright?
We bought pre-made LED rings. Red and Blue were out, too much potential for on-field confusion with alliance colors. Yellow wasn't very bright, so green became the color. White were more expensive.
They really do not have to be that bright, the retro-reflective tape is pretty good. One AA Mag-lite might work OK, for example.
Unread 30-03-2012, 08:23
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
This year we also purchased the premade rings (and cover) and had no problems (we even used blue). At our week 2 event green, purple, and other "odd" colors seemed popular.
This was after an exercise in students trying to make their own array and it not turning out so well.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 01-04-2012, 00:27
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I have seen at least one team using what appeared to be a diffuser on their ring-light. Wouldn't this diminish the retroreflective effect and/or interfere with your alliance partners aiming?
Unread 01-04-2012, 01:29
You want the light to be emitted in a wide pattern rather than directionally. That way the targets will still be reflecting when they're not directly in front of the robot.
Unread 01-04-2012, 07:51
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
LEDs tend to be very directional. Adding a diffuser will widen the area of illumination, but will weaken the amount of returned light.
Fortunately you dont need much returned light and you can block out all but the exact wavelength you are looking for, meaning that you will need to do some teating but as long as the returned light is detectable, the amount of returned light does not need to be a lot.
___________________
- Tennyson, Ulysses
Unread 03-04-2012, 17:11
purduephotog purduephotog is offline
Active Defense Design Engineer
AKA: Jason
FRC #3015
purduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the roughpurduephotog is a jewel in the rough
Send a message via AIM to purduephotog
I built a demo illuminator that used 3 Cree xrc green less running at 300 ma . If they were more than 10 cm outside the range of the camera the reflection fell dramatically. When using the ledil optics I could not get a wide enough beam angle. It was flooding the camera.
We have 9 xrc less now on tristars that can illuminate across the entire field, but the team is using the largest angel eye instead.
http://purduephotog.deviantart.com
Portrait Photography: "I used to say Immortalized in Silver, but now I say Captured and Squeezed by Electrons".
Unread 07-04-2012, 21:47
JP Carlin's Avatar
JP Carlin JP Carlin is offline
FRC #2487 (Mechanical Animals)
JP Carlin is on a distinguished road
We used some green leds this year to use for our auto-aim system which even though the auto-aim failed we kept them on cause they looked cool.
First year that we ever used these and for the time that we needed them they worked beautifully so ill try to have the team give em another shot next year
