Go to Post I've now read Dolly Parton's entire wikipedia page, which was not something I expected to do - WinterPoet [more]
Unread 27-03-2012, 18:50
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: Window motor or FP W/ Gearbox?
Originally Posted by pfreivald View Post
I suggest that you consult your local physics teacher or mechanical engineer. He/she can teach you the relationship between power, torque, and angular speed -- and how to convert that into a linear time on a 22-inch pull.
With the torque/power specifications of a particular motor/gearbox combination, you will then have all the tools necessary to make the right decision for the application.
22lbs * 1.5 inch lever arm for a 3 inch spool = 33lbs*inch=528 oz*inch
528oz*inch / 121 (reduction in FP gearbox) = 4.33 oz*inch
RPM @ 4.33oz is approximately 19000RPM at motor, 157 RPM at output.
24 inches/s assuming 100% efficiency after the motor output.
Using specs for the 801-0673 FP
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
