Go to Post If your robot can't play at least two matches on one battery, your mechanical design and/or driver strategy needs some rethinking. - Al Skierkiewicz [more]
Unread 27-03-2012, 18:51
uknowwho12 uknowwho12 is offline
FRC #0967
uknowwho12 is an unknown quantity at this point
Team Buttons/Pins
My brother is on an FRC team, and I would like to make team buttons for competitions and such. Since I'm inexperienced with this whole idea, it would be great to get a couple of answers from some people who have done this before:
- Do you make your buttons yourself (with a press/machine/etc.)? Or do you order them "pre-made"?
- If you make them, what do you use to do so?
- If you order them, where can I do this?
- What kind of budget do you set?
- How many do you make/order?
Any suggestions you can offer would be great. Thanks for your help!
Unread 27-03-2012, 19:45
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Re: Team Buttons/Pins
We do happen to make our own buttons for promotional giveaways. Our promotions team in the last few years has invested in two machines to make the buttons by hand. The first machine is a simple die cutter that will cut out your printed paper blanks, the second is the actual button press. I don't know the cost of the equipment off the top of my head but it can be well worth the investment if you compare the cost of buying them to making them (ex. $1.20(exaggeration):$0.17. The $0.17 is pretty close, the other number depends on the supplier). Once you have the equipment, the supplies to make the buttons can typically be found at an arts a crafts store and the printing can be done on any printer you have available.
As far as quantity goes if you make/order non game specific buttons you can run over on your number and use them next year. One of the advantages for making your own is buying the supplies in bulk and using them for custom buttons one season and storing the materials for future use. If you make them or order them plan to have enough made to cover all of the judges at a competition and at least one for every team at minimum.
They are rather time consuming to manufacture in bulk but it gives everyone something to do between competitions and during slow spots in the build season. It gives your promotions team another creative and artistic activity to participate in and can save your team money in the long run compared to buying them.
Unread 27-03-2012, 19:57
DonRotolo's Avatar
Back to humble
FRC #0832
One such machine supplier is "badge-a-minit" (google it). They may not be the least expensive though, I have not done any research. Don't only consider the machine price, but the supplies price as well because you'll be using a LOT of that stuff.
Basically, we print the button on a color laser printer (several per page), cut out the circle using a circle cutter, then load into the button press: A clear cover, the paper (face down), a badge front, and a badge backer. Whack the press, and out pops a badge.
Our press spins 180 degrees, so while person A is loading one press hole, person B is whacking the press. Spin & repeat. Our is NOT a badge a minit product, their supplies were too costly.
Unread 27-03-2012, 20:22
Jin Hayashi's Avatar
Jin Hayashi Jin Hayashi is offline
FRC #2930 (Glacier Peak Robotics - The Sonic Squirrels)
Jin Hayashi will become famous soon enough
Our team bought an all in one kit that included a punch, button maker and button supplies from Buttonmakers.net
For my team, they are a local company. Whether or not you purchase from them, their website includes several tutorial videos and templates for making buttons.
We made 750 buttons for the Seattle Regional and saved some for each day of the competition.
Carol's Avatar
Carol Carol is offline
FRC #0365 (MOE)
Carol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond reputeCarol has a reputation beyond repute
We must have the same equipment as Don; the seems the same. We got our's from Dr Don's Buttons (not the same Don). Some of our buttons are printed on a color laser; some are photocopied on lime green paper.
MOE 2007 Chairman's Video by MOE video team and Paul Lazarus http://moe365.org/CHMN_AWD_video_2008.php
MOE 10-Year Video Celebration on YouTube http://www.youtube.com/watch?v=ETcSMUBUqEs
Unread 27-03-2012, 21:21
kgalea kgalea is offline
FRC #3175
kgalea is on a distinguished road
We order ours...
Last year we ordered 1000 buttons and had a few left over for this year. I don't remember the exact price since a parent from our team donated them, but I am sure they were not $1.20 each and we had 3" buttons.
This year, we ordered bracelets (similar to the Livestrong ones) that were $0.38 each - they were black/red marble with our team number embossed in them. We went through 1000 of them quickly, so I'd say they were a big hit.
Both items were ordered from a local supplier here in MI. I will provide you with info if you are interested.
Unread 27-03-2012, 21:28
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
One team at the WPI Regional had taken a small rectangle of 1/4'' aluminum, rounded the edges and CNC'd both sides. One side said WPI Regional 2012, the other had the Rebound Rumble logo. They drilled a hole in it and stuck a keychain on it. I thought that was pretty cool! It's on my keys
Unread 27-03-2012, 23:19
Max Meaker's Avatar
Max Meaker Max Meaker is offline
Robotics Club Co-President
FRC #3786
Max Meaker is on a distinguished road
I wasnt very involved with my team's button making (not a high priority if you ask me haha) but several members of my team made around 1,000 buttons with our button press, which took quite awhile, but at the end of the Seattle Cascade regional, they were all gone.
Unread 28-03-2012, 16:39
FRC #0967
These are all awesome answers. They were all super helpful! Thanks!
Unread 29-03-2012, 08:31
S.P.A.M.er's Avatar
S.P.A.M.er S.P.A.M.er is offline
Horizontal Engineer (12N)
AKA: Emma J. Harland
FRC #4901 (Garnet Squadron)
S.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud ofS.P.A.M.er has much to be proud of
I know that it's always essential to over make buttons because we always have people asking for them.
2011-2014 FRC 180 S.P.A.M. Student
time as a 180 student: 5 regional wins, 1 Divisional win, 1 World Championship
2015-20?? 4901 Community Outreach Mentor
Proud USACE Soldier
posts do not reflect the views of anyone other than myself
Unread 29-03-2012, 09:07
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
One thing you gotta remember is a great design for the button. I get buttons from every team possible but unique ones go up on a banner in my home. Be it the style of the button or some student hand drew a design on the button or just something epic, make sure your button stands out.
And a side bar as to why I keep a team button around, if you ever have a DVD drive on a computer that's being problematic, you have yourself a pin that you can use to open up said drive.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 29-03-2012, 09:22
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
This year we made 500 team logo buttons, and about 200-300 each of a few different "specialty" buttons. Our buttons are assembled by the Special Needs students at our school. We used 5 different designs, including "Where's the Sharpie?" and our famous(?) "Honey Badger" button. At Orlando, the specialty buttons disappeared quickly (by Friday AM), and we had requests for them well into Saturday. At Palmetto, we scaled back to 2 specialty buttons and asked for donations for them to raise money for The American Red Cross. Happy to say we raised over $175 for this worthwhile charity.
FRC Team 3489 "Category 5"
Unread 29-03-2012, 12:12
Carol's Avatar
FRC #0365 (MOE)
A few years ago I priced out the cost of the buttons we make - it came to 15-25 cents per button, depending on the paper used and number of buttons blanks ordered (buying in bulk is cheaper).
Unread 30-03-2012, 02:35
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
And that's typically when you find out that you have absentmindedly put a button in your DVD tray which is what caused the problem to begin with.
Unread 30-03-2012, 08:19
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
http://store.schoolspecialty.com/OA_...minisite=10064
Is the company we purchase our button materials from, hope its helpful to people.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
