Go to Post Time to iterate, more. - jwfoss [more]
Unread 07-01-2003, 01:21
RichardBCR RichardBCR is offline
#0294 (Beach Cities Robotics)
RichardBCR is an unknown quantity at this point
Nippon Denso Window Motor Specs
Anyone got the motor specs or a link to them for the Nippon Denso Window motor?
Ie stall torque and other usefull pieces of information?
Unread 07-01-2003, 09:01
President, VEX Robotics, Inc.
I am working on it.
Paul
Unread 07-01-2003, 20:19
sounds good, will wait for your response.
Unread 10-01-2003, 10:51
Unresponsive
Well I think I have just met the most unresponsive motor supplier to date.
I was told I would have some answer 2 days ago and still no response.
Sorry.
To date, I have only confirmed the drill motor, Globe, F-P, & Chiaphua motors.
Unread 10-01-2003, 12:23
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Re: Unresponsive
Originally posted by Paul Copioli
...To date, I have only confirmed the drill motor, Globe, F-P, & Chiaphua motors.
Do you have these up and ready yet Paul? Thanks for all your help....
Ricky Quinones
Director of Sales - VEX Robotics
Unread 10-01-2003, 12:36
Start New Thread
I will start a new thread under motors to give out the info, but the F-P excel sheet is in the Motors forum already. Look here:
http://www.chiefdelphi.com/forums/sh...threadid=15967
-Paul
Unread 13-01-2003, 15:43
Derek Rebel's Avatar
Derek Rebel Derek Rebel is offline
#0783 (Mobotics)
Derek Rebel is an unknown quantity at this point
Send a message via ICQ to Derek Rebel
How's the Denso motor specs coming along?
Qui Desiderat Pacem, Praeparet Bellum
Unread 15-01-2003, 21:20
I Take It Back
I just received the specs (by fax) from Denso. I take back my derogatory post above. Mr. Carl Vaugh at Denso had to search the archives for our motor, which is quite a few years old. Thank-you. Right now I am reading through a 12 page Ford Spec on the motor and trying to pull out the motor data. I will reproduce the drawing with all the mounting dimensions and upload it in the morning.
The Torque-Speed curve did not come through in the Fax, so I will get with Carl in the morning to clarify.
Once again, thank-you Carl.
-Paul
Unread 16-01-2003, 11:06
P.J. Baker's Avatar
P.J. Baker P.J. Baker is offline
needs a clever user title
FRC #0177 (Bobcat Robotics)
P.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of light
Model and year
Paul,
For those interested in purchasing window lift hardware that goes with the denso motor it would be useful to know the make (apparently ford) model and year(s) that they were used. Did that info come to you? If not, do you think your contact can get it?
Thanks,
P.J.
Unread 18-01-2003, 14:20
Solon Jhee's Avatar
Solon Jhee Solon Jhee is offline
#0302 (LOHS & Daimler Chrysler)
Solon Jhee is an unknown quantity at this point
Send a message via AIM to Solon Jhee
I was wondering if anyone did get these specs, we cant find the window motor specs anywhere, i would greatly appreciate it if you could send them possibly to my email at Fierycosmic@lycos.com
Thanks
Unread 21-01-2003, 20:30
Moshingkow Moshingkow is offline
Moshingkow is an unknown quantity at this point
Hey Paul
Whatever happened to you uploading the window motor specs? If you did, it would be alot of help for my team. Also, I am thinking of using either the window motor or the globe motor to power a grabbing mechanism, but I need a motor which will stay in a position when it is put there, so that when I take off the power, it will not drop the box. I have to take off the power because if I dont, it will be operating in stall conditions, which will burn out the motor, or so I think...
Thanks
Unread 22-01-2003, 09:46
What I have so far...
O.K.,
Here is what I have so far from the manufacturer (these are really old motors and finding the specs has been challenging):
Stall Torque = 5 -m
Free Speed = 95 RPM
Free current = 2.8 amps
I hope this helps.
We have also done testing on the backdriveability of these things. With the power turned off and using a 1" shaft directly coupled to the motor to wind up a string, the motor would not backdrive using 300lbs of weight.
-Paul
Unread 25-01-2003, 11:22
FIRST has Uploaded Info
I had a typo that I did not catch (I could not read the print that I had very well). To summarize the info from FIRST:
Stall Torque = 9.3 N-m
Free Speed = 92 RPM
Free Current = 2.5 amps
Stall Current = 25 amps
This is at 12.6 volts.
-Paul
Unread 26-01-2003, 07:01
Mr.G Mr.G is offline
AKA: Kevin
FRC #0326 (Xtreme Eagles / Romulus High School / General Motors)
Mr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond reputeMr.G has a reputation beyond repute
Send a message via AIM to Mr.G
Anyone found a source for purchasing window motors yet?
Or a part number to order through a dealer?
Thanks
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
Nippon Denso, how to get a spare caffel Motors 1 24-01-2003 14:49
Looking for window kit parts archiver 2000 2 23-06-2002 22:50
Re: window motors archiver 1999 1 23-06-2002 21:56
