Go to Post Team 71: So good at Strategy they already have figured out next years game before the GDC has even met. - IKE [more]
Unread 28-03-2012, 07:42
Re: Vision Processing and Periodic Tasks stops working
Probes should not need to be added to the VI before running in order to work, and that didn't impact the issue in the bug report I filed. It appeared that the node identifier used to describe where the probe or breakpoint was added didn't match where the compiled code's offsets were. As I said, I've never seen this before and it currently seems to be RT specific. I'll know more in a few days. In the meantime, probes in most VIs work fine. If they claim not to be updated, that could be a false statement. I also saw issues with breakpoints not working.
I'll be happy to try and reproduce and explain what is going on with the code that is no longer running, but I'll need something to reproduce it. I asked Tom for his code. If you also have a repeatable case, either go through support or PM me.
Greg McKaskle
