Go to Post I'm still trying to find a way to get FIRST to dump the Chicken Dance song. :p - Koko Ed [more]
Unread 28-03-2012, 09:49
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Turning on the bridge
Reading through all the threads about 3 bot balancing I've seen a lot of teams with a narrow front robot talking about how they can turn sideways on the bridge and do a 3 bot balance. My team is one of those narrow front bots so I'm looking for as much info as I can get to make it happen.
Specifically I'm wondering;
-Has anyone ever seen this plan work? (video would be awesome)
-Is the turning bot usually the first or second bot on the bridge?
+If the narrow front bot is the first bot and it's balanced after turning can other bots easily get the bridge down?
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 28-03-2012, 09:51
pfreivald's Avatar
AKA: Patrick Freivald
Re: Turning on the bridge
I've seen plenty of turning on the bridge, but not to triple-balance. A zero turn radius and an omnidirectional drive is probably essential to pull this off.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 28-03-2012, 10:35
Samk Samk is offline
Lead Builder
FRC #0619
Samk will become famous soon enough
We have an 8-wheel drive, middle two dropped, and though we have not accomplished it at competition, we have been abe to turn sideways while maintaing balance.
Unread 28-03-2012, 10:37
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Why would omnidirectional drive be essential? If there's a sideways bot on the bridge, surely the other two could push it into position - especially with the low-friction HDPE. If there's one thing we've learned about balancing, it works best when only one robot is moving.
Hi!
Unread 28-03-2012, 10:40
pfreivald's Avatar
In my experience thus far, pushing a dead-weight robot that is turned sideways on its wheels up a polycarbonate slope is harder than it seems. So I guess I'd say "essential unless you have a monstrous drivetrain and very good traction on the polycarb".
Team 1551
I write books, too!
Unread 28-03-2012, 10:47
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
Where is there low friction HDPE? The polycarbonate on the bridges is quite grippy against many types of rubber wheels. That includes the kit wheels from this year, last year, and also any pneumatic wheels that may be in use. I can tell you right now, with pneumatics in the middle and omnis on the back of our bot, there wasn't a team we met that could push us sideways on a bridge (especially uphill).
I can't remember who it was, but I did see this in action on a video on CD, they turned as they got to the end of the bridge. The only issue there is being sure that you don't get hung up on the field wall and lost your balance points.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 28-03-2012, 10:52
pfreivald's Avatar
Geared down 45:1 with four CIMs and roughtop tread we couldn't push many robots up the bridge even in line with their wheel base; that is to say, as long as our back wheels were on carpet we had no problem, but as soon as all four wheels were on the bridge we needed a little help. Rubber wheels likely would have worked better, but I still think it would be nigh-impossible (though not actually impossible, of course) if the robot was perpendicular to its wheel base.
We could do the math, of course, to find out what torque would be necessary -- though we'd need the coefficient of friction of both the pushing robot's wheels on polycarbonate, and the pushed robot's wheels.
Team 1551
I write books, too!
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
We are looking to implement something similar to this for Mount Olive. With our 6wd tank drive we can get roughly a zero degree turning radius. This would allow us to turn on the bridge for a triple balance. For this to work we would need two other wide bots on our alliance, and one with a great drive train. It would require the weaker bot to knock down the bridge and go up first, followed by us (we would need to be fully on the ramp before we could turn), and than have the strong robot push our robot into the center.
Obviously this is a perfect scenario and their are a lot of factors that play into this...but it should be interesting to see what happens at Mount Olive.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRST® or my affiliated team.[/center]
FRC® Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
Unread 28-03-2012, 11:03
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
There are plenty of examples of long base bots being part of triple balances without turning sideways as an end position bot. In fact if your bot's CG is biased toward front or back you will take up less room (+/-23" vs +/-28" for a wide bot) on the bridge if you just "let er hang" with lighter end of bot hanging over the edge of the bridge.
Unread 28-03-2012, 11:10
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
That's how 222 plans to triple balance if the need arises
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 28-03-2012, 11:29
legogeek24's Avatar
legogeek24 legogeek24 is offline
AKA: Dirk
FRC #3562 (LiveWire)
legogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura aboutlegogeek24 has a spectacular aura about
When 3456 triple balanced in Utah (albeit on the practice field), we were successful with two long robots and one wide robot. My team drove up first and turned sideways at the far end of the bridge (we are about 104 pounds with a true zero degree turn radius). The wide robot came up the middle, while the long robot, the heaviest of the three, helped to hold the bridge down while slowly pushing the middle bot forward. They ended up hanging off the back, but it worked!
I feel turning sideways is a viable strategy, with the right robot. We're almost 6 inches shorter than max length and have two wheel drive, so it worked well for us and probably would for similar robots. Still, at least one wide robot seems to be required to pull it off.
4 year FIRST alumnus and current MIT Computer Science student
Mentor for LiveWire 3562 and The Arabian Knights 4928
"1...2...3562!!!"
Unread 28-03-2012, 12:31
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
I didn't see it in person, but the San Deigo Regional alliance of 1661, 599, and 2599 used turning after being on the bridge as a fundamental part of their triple-balancing technique.
Video of a triple-balance where both 2599 and 1661 turn sideways (1661 at the last moment, high on the bridge) can be seen at http://www.youtube.com/watch?v=8T8B9f_YQpY
Close-up video of a match where 1661 doesn't make the turn but instead hangs about one-third off the bridge can be seen at http://www.youtube.com/watch?v=3ZaV5qj65_E
A description of what they did, written up by Mr. Van of 599 is at http://www.chiefdelphi.com/forums/sh...3&postcount=54
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 28-03-2012, 13:42
wireties's Avatar
wireties wireties is offline
Principal Engineer
AKA: Keith Buchanan
Our mecanum drive can do this - drive up the ramp, balance and pivot in the middle. It is pretty quick. We have the Andymark HD wheels which have a little better grip than the standard wheels (seems like). They are even tough enough to go over the bump quickly.
HTH
Unread 28-03-2012, 15:58
bam-bam bam-bam is offline
bam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond repute
HTH
Or the mecanum drive can turn (into the wide side parallel to the edge of the bridge) and strafe while the bottom robot pushes the other robots up.
That goes without saying if you don't have traction on your alliance, you lose (which I find is incredibly hard to do because there are so many robots with great traction).
Unread 28-03-2012, 16:17
wireties's Avatar
Principal Engineer
AKA: Keith Buchanan
agreed - we normally get to pick and there are many great hi-traction bots that can shoot and/or play great defense to select from.
