Go to Post Be realistic in your goals, and relentless in hitting them. - IKE [more]
Thread Tools Rating: Thread Rating: 72 votes, 5.00 average. Display Modes
Unread 19-03-2012, 12:14
Re: Week 3 OPR - All regionals/district and World ranking
Originally Posted by JB987 View Post
Inclusion of CP a good idea but not sure it is enough as formulated to compensate for the amount of TP lost during final 45 to 60 seconds almost every match for our team on the Co op bridge as we focused more on guaranteeing first seed than racking up points.
I haven't been able to open Ed's spreadsheet, but from what I've read I assume he has reported each Team's least-squares calculated contribution to Hybrid, Bridge, TeleOp, and CP separately so that the user can blend them any way he deems most appropriate.
Unread 19-03-2012, 13:05
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
The Jumbotrons in VCU did a great job of sucking some OPRs dry.
We aim to please in Raleigh.
Unread 19-03-2012, 13:27
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
This is more or less impossible to do without any data on what was the average time left in the match when that specific team started to balance the Coop Bridge, as I'm sure this value will vary from team to team. Some teams may play it safe and start to balance much sooner, while others may push their luck.
Even for the same team, I would expect this time to vary from event to event based upon the average match difficulty (among other variables). Teams at weaker events will likely start balancing the bridge sooner to ensure that teams with weak bridge tippers and/or weak/slow drivetrains can make it onto the bridge, while teams at stronger events will likely spend more time scoring during Teleop to both help secure a win and because of a higher confidence that a balanced bridge can happen in a shorter time span.
Art Dutra IV
世上无难事,只怕有心人.
Unread 19-03-2012, 13:37
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
You get 10 bridge points for balancing on the coop bridge which is the same if you were to go to the alliance bridge to balance on your own or with a partner. I think this is Bongle's reasoning to choose to do it this way.
Ether, I added columns to show adjusted OPR bridge points and overall OPR and use that for ranking purpose. Teams can change the number of points for each Coop bridge point but the ranking will not be recalculated. I am still trying to write out in .xls format but without any luck so far.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 19-03-2012, 13:56
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
My reasoning was that the 2 CP points earned by each alliance could have been 10 bridge points for each alliance if their alliance members had decided to go for the alliance bridges instead of the CP bridge.
Really, I should've just left the adjustment only in the bridge category rather than also including it in the overall OPR as well. But several sets of stats had already been posted, and removing it would make week-against-week comparisons difficult. The reasoning for including it in overall OPR was that teams who were on the CP bridge every match rather than the alliance bridges would rank very low in the "prestigious" overall OPR, even though they could've ranked quite high if only they'd balanced a different bridge.
Unread 24-03-2012, 21:32
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Originally Posted by bam-bam View Post
According to what I've found, 620 does not exist at all.
Where did you look?
http://www.thebluealliance.com/team/620
Does anyone else remember when TBA signatures actually worked?
Unread 24-03-2012, 21:36
bam-bam bam-bam is offline
bam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond repute
Originally Posted by bduddy View Post
I failed- accidently looked up 1620 by accident. Just noticed that now.
Thanks.
Unread 24-03-2012, 21:39
Or here. Ranked #16 at PITT
Unread 26-03-2012, 14:03
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Is the week 4 OPR list available yet?
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 28-03-2012, 13:20
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
How about right now? Is that fast enough service for you Don?
Version 3.1 is out. It includes data from New York and all OPR including world ranking has been recalculated.
I can't find our team's OPR. The only NY team I can find on there is 1676.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 28-03-2012, 14:10
Is this not it?
Unread 28-03-2012, 15:49
jblay's Avatar
AKA: Joe Blay
Weird, it appeared blank to me before. Maybe I downloaded and old version.
