Go to Post The great thing about autonomous mode is that it doesn't require any additional effort from anyone else on your team... (You could do that yourself...but I've noticed that people will usually offer to do it for you, rather than let the programmer touch power tools.) - jgannon [more]
Unread 28-03-2012, 21:36
thecakeisalie's Avatar
thecakeisalie thecakeisalie is offline
FRC #0293
thecakeisalie is an unknown quantity at this point
Netbeans setup issue
So, I figured I'd test java a bit and installed the netbeans + frc plugins.
The only problem is that when I try to create a new command/subsystem by doing right click -> new -> command.../subsystem..., it is not there! The only options are new java class, java package, and java interface. Any help on getting this working would be much appreciated.
I'm using netbeans 7.1.1, though i don't think its an issue, as the netbeans version they are using in the video tutorials are 7.0.1
