Go to Post No really though, a robot game with rules similar to Risk. This would combine FIRST, Battlebots, and US Government... - Betty_Krocker [more]
Unread 22-03-2012, 10:32
Team1605 Team1605 is offline
FRC #1605
Team1605 is an unknown quantity at this point
Help !!!!
i need serious help how can i get the buttons to work on my joystick how do i program it ??? here is my code is it correct ??
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Joystick.AxisType;
import edu.wpi.first.wpilibj.*;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the SimpleRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Team1605 extends SimpleRobot {
    Joystick stickDriverLeft = new Joystick(1);
    Joystick stickDriverRight = new Joystick(2);
    Jaguar leftMotor = new Jaguar(2);
    Jaguar rightMotor = new Jaguar(1);
    Jaguar shooterMotor1 = new Jaguar(3);
    Jaguar shooterMotor2 = new Jaguar(4);
    Jaguar gatherMotor1 = new Jaguar(5);
    Jaguar gatherMotor2 = new Jaguar (6);
    RobotDrive robotDrive = new RobotDrive(leftMotor,rightMotor);
    Shooter shooter = new Shooter(shooterMotor1,shooterMotor2);
    Gatherer gatherer = new Gatherer(gatherMotor1, gatherMotor2);
    final int TRIGGER_NUMBER = 1;
    final int GATHER_START_BUTTON = 2;
    final int GATHER_STOP_BUTTON = 3;
     * This function is called once each time the robot enters autonomous mode.
    public void autonomous() {
     * This function is called once each time the robot enters operator control.
    public void OperatorControl() {
        while(isOperatorControl() && isEnabled())
        robotDrive.tankDrive(stickDriverLeft.getAxis(AxisType.kY), stickDriverRight.getAxis(AxisType.kY));
        if(stickDriverRight.getRawButton(TRIGGER_NUMBER)) {
           shooter.set(1);
        else {
            shooter.set(0);
        if(stickDriverRight.getRawButton(GATHER_START_BUTTON)) {
            gatherer.set(1);
        else if(stickDriverRight.getRawButton(GATHER_STOP_BUTTON)) {
            gatherer.set(0);
        Timer.delay(.01);
Unread 22-03-2012, 13:02
2869Robotics 2869Robotics is offline
FRC #2869
2869Robotics is an unknown quantity at this point
Re: Help !!!!
The way that you have your trigger set up. As long as you hold the trigger down the shooter will be set at 1 but if you let go of the trigger it will be set back at 0. Do you want the trigger to toggle the shooter on and off?
Unread 28-03-2012, 13:37
NS_Radication's Avatar
NS_Radication NS_Radication is offline
Student
AKA: Marco Schoener
FRC #1369 (Minotaur)
NS_Radication is an unknown quantity at this point
Re: Help !!!!
Can someone posta code for a toggle button or for an array of buttons that can change speeds with a press, not held down? This would be very help!
Thank you and Happy Competition!
Team 1369
Senior
Head Programmer (Java)
Head Electrician
Unread 28-03-2012, 15:23
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
Re: Help !!!!
Both toggle and cycle buttons are based on a button "press" instead of just being held down. To detect when a button is pressed:
// outside the "checking" loop
boolean prevState = false;
// inside checking loop; can be within continuous or periodic
boolean currentState = joy.getRawButton(DESIRED_BUTTON);
if(currentState && !prevState) {
    // Button DESIRED_BUTTON is newly pressed
    // Do stuff here
prevState = currentState;
To do a toggle, have an extra boolean (e.g. tracking), then when the button is pressed:
tracking = !tracking;
To do a cycle, have an int (e.g. basketChoice) and do this on button pressed:
basketChoice = (basketChoice+1)%NUM_CHOICES;
Unread 28-03-2012, 15:52
FRC #1605
Re: Help !!!!
i need help. in tank drive one of my wheels keep spinning and the other responds properly with one joystick.MY SHOOTER GATHERER AND BRIDGE HAND WORK. how can i fix this. this is my code :
/* the project.                                                               */
 * directory.
    Victor bridgeHandMotor = new Victor(7);
    BridgeHand bridgeHand = newBridgHand(bridgeHandMotor);
        robotDrive.tankDrive(stickDriverLeft.getAxis(Joystick.AxisType.kY), stickDriverRight.getAxis(Joystick.AxisType.kY));
        if(stickDriverRight.getButton(Joystick.AxisType.kTrigger)) {
           shooter.set(1);
        else {
            shooter.set(0);
        if(stickDriverLeft.getButton(Joystick.ButtonType.kTrigger)) {
            gatherer.set(1);
        else {
            gatherer.set(0);
            bridgeHand.set(stickDriverRight.getAxis(Joystick.AxisType.kX));
Timer.delay(.01);
Unread 28-03-2012, 23:59
Student
AKA: Marco Schoener
Re: Help !!!!
What can this do? Could this be used to add a ball count to the robot.
Team 1369
Senior
Head Electrician
Unread 29-03-2012, 10:20
Ginto8's Avatar
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Re: Help !!!!
This is called modular arithmetic. You probably don't want to use that particular method for counting balls, because if, for example, your NUM_CHOICES were 3, then as balls enter the count would go 0,1,2,0,1,2, instead of 0,1,2,3,4 as they entered and 4,3,2,1,0 as they left.
