Go to Post Taking some parts from an old robot isn't cheap, it's like adding a piece with more experience to the new robot. - Marcel [more]
Unread 07-01-2003, 20:23
mrobrien mrobrien is offline
#0972 (Steelpaws)
mrobrien is an unknown quantity at this point
Send a message via ICQ to mrobrien
The gears that come in the kit
does anyone know about how efficient the right-angle gears are that come in the kit?
Unread 07-01-2003, 20:53
Randy_VanW.'s Avatar
Randy_VanW. Randy_VanW. is offline
Randroid, the Android
#0240 (Mach Vee)
Team Role: Driver
Randy_VanW. is an unknown quantity at this point
Send a message via MSN to Randy_VanW. Send a message via Yahoo to Randy_VanW.
Last I heard that the type of gears in the kit were 70 - 85% efficent if lined up perfectly. On that note the gear boxes are plastics, can you say fragile?
Unread 07-01-2003, 21:20
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
that plastic is pretty #%#%#%#% strong . . . I don't think any bots will wind up breaking it unless they run 3 motors through one of them at extremely high torques.
Which shouldn't be a problem . . . it seems speed/manuverability will be in this year . . if you can get up the ramp your fine.
of course, some bots will be high torque . . protect bots, attack bots . . . but not our bot!
Unread 07-01-2003, 23:37
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I believe that design makes the gears tougher though. They have more surface area between the two gears. Might be wrong though. They look cooler though!
Team Website
Unread 08-01-2003, 23:13
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
woooooooo hoooooooooooooo helical gears!!!
bad
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 08-01-2003, 23:20
D@ve's Avatar
D@ve D@ve is offline
Make it Happen
AKA: David Ferreira
FRC #0078 (Air Strike)
D@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of lightD@ve is a glorious beacon of light
Send a message via AIM to D@ve
hey Free grears rock! and when there already made is another plus. They seem just as rugged or even more then i thought.
Not saying were using them though!
Unread 08-01-2003, 23:30
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Free Gears are even better.
Unread 09-01-2003, 00:44
Moshingkow Moshingkow is offline
Moshingkow is an unknown quantity at this point
my team is thinking of using that gearbox, as it seems like the most simple design we could think of. Any suggestions on how effective they may be? should we scrap the idea because they will eat up the power?
Unread 09-01-2003, 14:12
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Efficiency
There is no set "Efficiency" associated with these gears. The efficiency is really a system measurement. Systems that use helical gears are less efficient than systems that use spur gearing due primarily to the fact that helical gearing produces an axil force in addition to a tangential force and radial force produced by spur gearing. This axil force increases the friction between the gears themselves and is translated to the bearings that hold the axils in place. The bearings will experience a much higher axil load in a helical gear system than in a spur gear system.
It is important to know that the helical gears should be kept lubricated. Running these things with little or no lubrication means a dramatic drop in system efficiency. It's also important to know if the bearings that support the axils can withstand the significant side loads (axil forces) that are generated. Make sure that these bearings are also well lubricated.
Roughly, efficiencies for helical systems can typically run in the 50-70% range. Spur gear systems run in the 80-95% range.
Here's a good site for some data QTC Gears
Ed Sparks
MECH TECH FRC-3959
Unread 11-01-2003, 22:31
Carl Owenby Carl Owenby is offline
#0654 (Maclay Robotics)
Carl Owenby is an unknown quantity at this point
Helical gear efficiency
The Boston Gear "Gear Catalog" states on p. 54 (p. 62 in the PDF) that helical gears with 90 degree shafts are approximately 50% efficient. This calalog may be found at http://www.bostongear.com/pdf/catalo...rs_catalog.pdf
There are 10 kinds of people in this world; those who understand binary and those who don't.
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Q&A Discuss: How many Van door motor(s) come with the kit? CD47-Bot Extra Discussion 1 08-01-2003 11:07
How many Van door motor(s) come with the kit? Ken Leung Kit & Additional Hardware 7 07-01-2003 21:40
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
