Go to Post if it's likely to break, it probably will - DonRotolo [more]
Unread 29-03-2012, 17:42
CompSciGeek CompSciGeek is offline
FRC #0948
CompSciGeek is an unknown quantity at this point
Quadruple Balance on Bridge
I would really like to see this. I'm sure it's possible.
Unread 29-03-2012, 17:52
wesbass23 wesbass23 is offline
FRC #1732 (Hilltopper Robotics)
wesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud of
Re: Quadruple Balance on Bridge
This would require working with the other alliance. Unless one alliance is ahead by enough that they are willing to do this just for fun, I do not think it will happen at a regional or St. Louis.
However, if you have 4 teams that are all based near each other and feel like hanging out, why not? It would make a cool video.
Unread 29-03-2012, 18:26
mikemat mikemat is offline
mikemat has a spectacular aura aboutmikemat has a spectacular aura aboutmikemat has a spectacular aura about
Triple balance with 118 hanging off the side? That would make an awesome wallpaper...
Unread 29-03-2012, 18:29
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
You would need 67 with 522 and their two twins.
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Unread 29-03-2012, 18:32
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Why not five 118 hanging and 179 hanging.. With a regular triple..
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 29-03-2012, 18:35
bam-bam bam-bam is offline
bam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond repute
Why not stack with 1501/2054/701 and two wide bots with both 179 and 118?
7 bots on a bridge!
Unread 29-03-2012, 18:36
You might run into some weighting problems with 179 hanging off the end...unless you stacked a robot on top of a 1501/2054 style deck at the other end.
Unread 29-03-2012, 18:39
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
That's what I call Coopertition. Sounds like a challenge for IRI: 2 bonus qualifying points for each pair of robot balances on the Coopertition Bridge at the end of the match.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 29-03-2012, 19:21
philso philso is offline
FRC #2587
The teams that do well don't just "meet the specifications", they go above and beyond. At least give it a try on the practice field.
Unread 29-03-2012, 19:36
Steven Sigley's Avatar
Steven Sigley Steven Sigley is offline
Electrical Mentor for Team 701
FRC #0701 (RoboVikes)
Team Role: Electrical
Steven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to allSteven Sigley is a name known to all
7 bots on a bridge!
This would be amazing. Though a triple bot stack would be soooo hard to pull off. No offense but I could only see it happening if there was a clone of our bot in the middle of the triple stack (for low CG purposes). And then a very short low CG bot on top.
2013 Colorado Regional Champions!
2013 Sacramento Regional Champions!
Unread 29-03-2012, 19:53
Jay1986's Avatar
Jay1986 Jay1986 is offline
Programmer and Driver
AKA: Jay Urban
FRC #1986 (Team Titanium)
Jay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the rough
7 bots on a bridge!
First of all, if you can even get 7 robots out in a match to play would be impressive. Try to ask the FTA if it can be a 4 vs. 3 match and tell me what they say.
2013 Oklahoma Regional (Regional Winner, Gracious Professionalism, [and judges voted me star of the day])
2013 KC Regional (Regional Winner, Woodie Flowers, Industrial Design)
2013 Hub City Regional (Regional Winner, Entrepreneurship, Quality, Dean's List)
Unread 29-03-2012, 19:54
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
WHAT TWINS??
Unread 29-03-2012, 20:07
#0341 (Wissahickon)
Originally Posted by waialua359 View Post
WHAT TWINS??
Just guessing!
Unread 29-03-2012, 20:19
One can dream....
Unread 29-03-2012, 20:34
Actually... They do just meet the specifications. However, they set their robot specifications higher than FIRST does.
In the real world, I need to meet or beat specs. But, at the same time, I might be the one setting some of the specs based on what the customer wants. If the customer says, "I want up to three robots on this place" and that place is big enough for three and not four (and barely big enough for three at that), then if I design for 4, 5, or 6 robots, I may be able to meet the customer's specification--but it's not a good solution, because it's outside the customer's needs/wants, and the time I spend engineering that solution can be better spent for other things, like putting as many basketballs as possible into a hoop 10' high, which the customer also wants.
