Go to Post they used the same random number generator we used for our autonomous drive code . . . (oops did I say that?) - MrForbes [more]
Go Back   Chief Delphi > Technical > CAD
Unread 29-03-2012, 20:44
Solidstate89's Avatar
Solidstate89 Solidstate89 is offline
CAD Leader
AKA: AK-Fo'7
FRC #1507 (The WARLOCKS)
Solidstate89 has a spectacular aura aboutSolidstate89 has a spectacular aura about
Re: NX?
Originally Posted by kramarczyk View Post
I use NX at work on a daily basis and I will say that I am very disappointed with the NX7 updates as compared to NX5.
Same. Delphi and GM have already moved on but we're holding on to using NX5 for as long as humanly possible. It doesn't help matters any that we have at least 3 fires going on right now and bringing an Assembly into NX7 from NX5 (even if fully and correctly constrained) BREAKS EVERYTHING! Any constraint it doesn't recognize will do one of two things; 1) remove the constraint entirely or 2) just make it completely fixed.
Both of which take hours to fix on a large compressor assembly.
