Go to Post To give credit where credits due, thanks to the GDC for this update. - Brandon Holley [more]
Go Back   Chief Delphi > Technical > CAD
Unread 24-03-2012, 19:25
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
NX?
I haven't seen it talked about in any forums, and can't find it in the search, so I would like to ask, what do you guys know about the CAD language NX, developed by Siemens. Do you like it? How hard is it to use?
Thanks!
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 25-03-2012, 00:26
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Re: NX?
I've only had experience with NX5 and I didn't like it at all. I hear NX7 is considerably better, but Autodesk is always a safer bet IMO.
Unread 28-03-2012, 10:34
Solidstate89's Avatar
Solidstate89 Solidstate89 is offline
CAD Leader
AKA: AK-Fo'7
FRC #1507 (The WARLOCKS)
Solidstate89 has a spectacular aura aboutSolidstate89 has a spectacular aura about
Re: NX?
NX5 is way better than 7. Trust me.
Unread 29-03-2012, 09:16
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: NX?
NX is another parametric modeler, like Inventor or Solidworks. Becasuse it is a different program it operates differently, not neccisarily easier or harder. The more systems you know the easier it is to pick up additional systems. In my opinion the hardest system to pick up is your second one, because of the paradigm shift it typically requires.
Whether NX is better or worse is dependant on your specific situation. I do not know of any donation program for teams like Inventor, Solidworks, and Pro-E (I cannot remember the new name) have, so it is generally more expensive for a team to procure. It does solid modeling, assemblies and drawings in a fairly standard manner that is suitable for FRC. It is broken down into a series of licenses, so just because you have the modeling license doesn't mean that you will get the FEA of NC modules. Because of this I would be inclined to use it only if a sponsoring organization was providing them for me and all I had to do was sit down.
I use NX at work on a daily basis and I will say that I am very disappointed with the NX7 updates as compared to NX5.
Mark
Brick walls are for other people. - Randy Pausch
Unread 29-03-2012, 20:44
CAD Leader
AKA: AK-Fo'7
Re: NX?
Same. Delphi and GM have already moved on but we're holding on to using NX5 for as long as humanly possible. It doesn't help matters any that we have at least 3 fires going on right now and bringing an Assembly into NX7 from NX5 (even if fully and correctly constrained) BREAKS EVERYTHING! Any constraint it doesn't recognize will do one of two things; 1) remove the constraint entirely or 2) just make it completely fixed.
Both of which take hours to fix on a large compressor assembly.
