Go to Post PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part. - dlavery [more]
Unread 29-03-2012, 22:05
farmersvilleRob's Avatar
farmersvilleRob farmersvilleRob is offline
FRC #4084
farmersvilleRob is infamous around these parts
RS-232 issue
We're using a sensor on our robot that uses the COM port on the cRIO to communicate information. We're having an issue getting any data from the sensor, though. We've used a COM port on a PC with the same cable we're using on the robot successfully. We've also adapted our Labview code to operate successfully on the PC with the sensor.
Does anyone have any ideas? Does the cRIO perhaps have swapped Tx and Rx pins compared to the standard PC pinout? (Not sure if it's considered a DTE or DCE). I did some googling and I'm under the impression that the pinout should be the same as a PC. Thanks in advance
Unread 29-03-2012, 22:08
Jay1986's Avatar
Jay1986 Jay1986 is offline
Programmer and Driver
AKA: Jay Urban
FRC #1986 (Team Titanium)
Jay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the roughJay1986 is a jewel in the rough
Re: RS-232 issue
woah, what sensor is this because sensors are usually only DIO or Analog.
2013 Oklahoma Regional (Regional Winner, Gracious Professionalism, [and judges voted me star of the day])
2013 KC Regional (Regional Winner, Woodie Flowers, Industrial Design)
2013 Hub City Regional (Regional Winner, Entrepreneurship, Quality, Dean's List)
Unread 29-03-2012, 22:19
Re: RS-232 issue
Make sure to disable the Console Out switch in the cRIo Imaging Tool.
Unread 29-03-2012, 22:26
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: RS-232 issue
Or physically disabled if you have a 8-slot FRC cRIO.
Unread 29-03-2012, 22:34
FRC #4084
Re: RS-232 issue
We will try this tomorrow. We figured something as much! trickster cRIO
