Go to Post A good robot can score a lot of points. A great robot can do it when the other alliance does everything they can to stop it. - Rick TYler [more]
Unread 30-03-2012, 11:36
Angkrit Angkrit is offline
Angkrit is an unknown quantity at this point
Event structure with unit change problems
Hello, how can I make the value change corresponding to the changed unit in the array?
For example, when I change the unit of "flow" to be L/hr, the value should appear from 4 to 240 in the data mainstream without adjusting the value manually. It should pop up automatically. I know how to change the unit but don't know how to make it appear in the data mainstream with the same numeric control block.
I tried to use an event structure but don't know exactly how to work around it.
Unread 30-03-2012, 12:35
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Event structure with unit change problems
See if this helps.
By the way, this isn't a NI or LabVIEW help site. This website is for the FIRST Robotics competition. For help with NI and LabVIEW help, please check out:
http://www.ni.com/
http://lavag.org/
We're here to help anyone, but with questions outside of FIRST, the responses will be slower.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 30-03-2012, 13:47
As Ryan said, this forum is mostly for the FIRST Robotics Competition, but you are more than welcome to join us. Just be warned that you might have to start a robotics team if you stick around.
It looks like the VI you attached is pretty close - the event structure is firing on the value change. However, the logic inside of it performs a unit conversion on all of the items in the array without paying attention to what the old units were.
To show this, set the unit to L/hr, type in a value, and hit enter. The value entered is mis-converted and replaced.
One way to work around this is with the "OldVal" node on the side of your event structure. This can help you find what the old unit was and convert (or not) as appropriate.
