Go to Post "at some point in the next six weeks you are going to start feeling like you are involved in a robot building contest. Then you are in serious trouble" -Dean Kamen - KenWittlief [more]
Unread 30-03-2012, 18:37
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Bridge scores visualized
As part of the OK regional webcast, I built a page to display the match results from the Twitter feed, with a simple visualization of bridge balancing. You can view it for all of the regionals with Twitter data here: http://www.botsnlinux.net/frcwebcasts/
Browsing through them, I was a little surprised how stark the differences were between the regionals. At the high end, the Livonia District has had a coopertition balance nearly every match, and several matches where all 6 robots got off the ground. On the other hand, the Oklahoma Regional is about 14% on the coopertition bridge, and there's been an average of about 1 robot balanced per match. Obviously the level of competition is very different between these events, but I didn't expect this much a difference. Thoughts?
PS - If anyone wants to see/use my code, just PM me.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 30-03-2012, 19:13
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
Re: Bridge scores visualized
It's something I've noticed a lot in watching webcasts, that the Michigan District teams have put a lot more work into the co-op bridge then other teams at other events. Not sure if it is a byproduct of the quaility of teams or if the district model promoted it much more, because of the need to seed higher for points.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 30-03-2012, 22:37
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Thanks for putting this together, Steven - it's a really helpful way of quickly seeing the balancing results! I noticed that the winning alliance (and score) are bolded for each match... while that can be noticed, perhaps a more noticeable way of highlighting the winning alliance/score would be good? Italicizing might stand out more?
Yeah, it is clear that most of the events this weekend haven't made significant use of the co-op bridges. The two Michigan Districts and the Connecticut Regional seem to be the distinct outliers. I would be more likely to attribute that to having a competition with a deep, well-practiced field, rather than the district model. As you can see, the week 3 MI events had substantially fewer co-op balances (although still more than most other events). All of those competing in MI this weekend have played in one event already, if not two... that seems like a big leg-up on the balancing... Similarly, many of those competing in Connecticut have already attended one event. These teams also have had more practice balancing and likely more fully realize the importance of co-op balances.
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 30-03-2012, 22:40
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
^At Virginia, the co-op bridge wasn't even balanced until Saturday, despite numerous attempts. I think at NCR, with 27 of 53 teams playing in a prior event, the co-op bridge will be balanced 75% of the time or more.
Unread 30-03-2012, 23:02
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
CT relied heavily on Coopertition. Even if they didn't have a chance at beating their alliance on score points, they would balance with them for the coopertition points for better ranking. Also had quite a few 2x2x2 balances. Can't wait until tomorrow's matches!
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
