Go to Post "Greatness isn't achieved by doing the uncommon things but instead by doing the common things uncommonly well." - Wayne C. [more]
Unread 30-03-2012, 21:13
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Custom GetRate not working.
Hi all,
We've heard that the WIPlib Encoder method getRate() is inconsistent, so we're trying to write out our own (better) without any success. Any suggestions?
private static double currGet = 0.0;
public static double getRate() {
double prevGet = currGet;
currGet = shooterEncoder.get();
int scalar = 50;
double rateDegreePerSec = Math.abs(currGet-prevGet)*scalar;
double rpm = rateDegreePerSec/6.0;
System.out.println("Rate: " + rpm);
return rpm;
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 30-03-2012, 22:58
Re: Custom GetRate not working.
Originally Posted by Mk.32 View Post
We've heard that the WIPlib Encoder method getRate() is inconsistent, so we're trying to write out own (better) without any success.
It's not entirely clear what you mean by "without any success". I will assume what you meant is that you are getting a signal, but it is very noisy.
        int scalar = 50;
        return rpm;
In the above code, you are not using the actual elapsed time since the previous sample to compute rate. You are assuming the scheduler's timing jitter can be ignored. Try reading a high-res system clock and dividing the delta_counts by the actual elapsed time.
Also, if you are not sampling the encoder at 1x, you might try that also:
Originally Posted by Joe Ross View Post
With 4x encoding, you get more noise in the velocity due to quadrature phase errors in the encoder wheel. I recommend 1x for velocity and 4x for distance.
Unread 30-03-2012, 23:39
Mk.32's Avatar
AKA: Mark
Sorry for the confusion, we are getting data back however it is very noisy and unstable.
Unread 31-03-2012, 01:02
Sorry for the confusion, we are getting data back however it is very noisy and unable.
Unstable.
Try using 1x instead of 4x, and try using actual measured elapsed time since last sample instead of a fixed scale factor.
If that doesn't work, check to make sure your encoder disk is installed properly.
Unread 31-03-2012, 03:18
Mk.32's Avatar
AKA: Mark
Here is a quick re-write I did, using all the above comments. Encoder is set to 1x.
Wouldn't get to test till next Wednesday. But comments are welcome.
    public static void shooterEncoderStart() {
        shooterEncoder.start();
        shooterEncoder.setDistancePerPulse(1.0 / 360.0);
    public static void shooterEncoderReset() {
        shooterEncoder.reset();
        double get1 = shooterEncoder.get();
            double time = Timer.getFPGATimestamp();
        double get2 = shooterEncoder.get();
            time -= Timer.getFPGATimestamp();
        double rateDegreePerSec = Math.abs(get2-get1)/Math.abs(time);
        return rateDegreePerSec/6.0; //RPM
Unread 31-03-2012, 09:46
The above won't work. "get1" and "get2" will be equal to each other and you'll always return zero.
You want to get the encoder count and the time once per iteration, and compare those values to the previous iteration.
Pseudocode:
new_counts = get_counts();
new_time = get_time();
rate = (new_counts - previous_counts)/(new_time - previous_time);
previous_counts = new_counts;
previous_time = new_time;
Unread 31-03-2012, 16:33
Mk.32's Avatar
AKA: Mark
Thank you for the help Ether, I will try it out next meeting!
