Go to Post If you have time to complain about how other people are making a difference, it's clear that YOU are not working hard enough to make a difference. - Foster [more]
Unread 31-03-2012, 03:18
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Custom GetRate not working.
Here is a quick re-write I did, using all the above comments. Encoder is set to 1x.
Wouldn't get to test till next Wednesday. But comments are welcome.
    public static void shooterEncoderStart() {
        shooterEncoder.start();
        shooterEncoder.setDistancePerPulse(1.0 / 360.0);
    public static void shooterEncoderReset() {
        shooterEncoder.reset();
    public static double getRate() {
        double get1 = shooterEncoder.get();
            double time = Timer.getFPGATimestamp();
        double get2 = shooterEncoder.get();
            time -= Timer.getFPGATimestamp();
        double rateDegreePerSec = Math.abs(get2-get1)/Math.abs(time);
        return rateDegreePerSec/6.0; //RPM
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 31-03-2012, 09:46
The above won't work. "get1" and "get2" will be equal to each other and you'll always return zero.
You want to get the encoder count and the time once per iteration, and compare those values to the previous iteration.
Pseudocode:
new_counts = get_counts();
new_time = get_time();
rate = (new_counts - previous_counts)/(new_time - previous_time);
previous_counts = new_counts;
previous_time = new_time;
Unread 31-03-2012, 16:33
Mk.32's Avatar
AKA: Mark
Thank you for the help Ether, I will try it out next meeting!
