Go to Post CIMs are NEAR indestructible and I <3 them for it. - Andrew Schreiber [more]
Unread 31-03-2012, 06:38
BrandonAbe BrandonAbe is offline
FRC #1025
BrandonAbe is an unknown quantity at this point
Axis 206 question!
How do I change my c++ code to make my camera show up brighter? When I do...
camera.WriteBrightness(100);|n=any integer≤100
...it is the same as....
camera.WriteBrightness(0);|n=any integer≤100
...Am I doing something wrong or is it just because it's the 206 and it has bad lighting?
I see other robots with lights on their camera, but when we took lights and surrounded our camera, it didn't help at all. Please help!! Finals are going to be today and our camera looks super dark so it's impossible to use :/
Thank you.
Unread 31-03-2012, 06:49
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Axis 206 question!
On your programming computer, open a browser and go to http://10.xx.yy.11
Make sure xx.yy is your team number.
Login as FRC/FRC (log/pass)
Find the advanced image adjustment options.
Find the "exposure" settings
Option 1:
Find a preset that works for you
Option 2:
Select "Automatic"
Shine a light into the camera, and move the light around until the camera auto-adjusts to the desire exposure time
Once adjusted, select "Hold"
Your exposure setting should now be persistent - even between power cycles
There is a great camera tutorial by HOT - 67, which details the process. I can't find it right now, as I'm on my way out to run errands.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 31-03-2012, 07:37
FRC #1025
Thank you!
Unread 01-04-2012, 10:00
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
These lights were available as selection from "FIRST Choice" at beginning of season. We found a significant difference between trying to add lighting by positioning lights around the camera and using one of these ring lights mounted with the camera lens pointing through the center.
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=%2Fmini_tubes. htm
Attached are some sample target shots using a ring of green leds.
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
