Go to Post I'm not gonna reinvent the wheel cause I can already buy it :) - Stephen Kowski [more]
Unread 31-03-2012, 09:46
Re: Custom GetRate not working.
Originally Posted by Mk.32 View Post
Here is a quick re-write I did, using all the above comments. Encoder is set to 1x.
Wouldn't get to test till next Wednesday. But comments are welcome.
public static double getRate() {
        double get1 = shooterEncoder.get();
            double time = Timer.getFPGATimestamp();
        double get2 = shooterEncoder.get();
            time -= Timer.getFPGATimestamp();
        double rateDegreePerSec = Math.abs(get2-get1)/Math.abs(time);
        return rateDegreePerSec/6.0; //RPM
The above won't work. "get1" and "get2" will be equal to each other and you'll always return zero.
You want to get the encoder count and the time once per iteration, and compare those values to the previous iteration.
Pseudocode:
new_counts = get_counts();
new_time = get_time();
rate = (new_counts - previous_counts)/(new_time - previous_time);
previous_counts = new_counts;
previous_time = new_time;
