Go to Post By the way, a piece of advice to all those who haven't gone to Manchester for Kickoff before: Go. It's something you have to do at least once in your time in FIRST. - Billfred [more]
Unread 01-04-2012, 11:47
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
pic: Triple Balance 2 of 3: CT Regional
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: Triple Balance 2 of 3: CT Regional
Does 118 now have a triple balance mechanism?
Unread 01-04-2012, 11:49
bam-bam bam-bam is offline
bam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond reputebam-bam has a reputation beyond repute
I'm pretty sure they do now.
If you check below 118, you can see part of its bridge mechanism blocked by a head.
And something tells me that this is the first time there was two stingers in a triple balance.
Unread 01-04-2012, 11:54
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
So when i was watching the CT regional they said that 228 could not have their stinger depolyed in the back court, because it would be taller than 60". Does this mean that in this photo 2168 is taller than 60" meaning that would be a penalty?
2014 Colorado Regional Winners (Thanks 3310 and 2543)
2013 San Diego Regional Winners (Thanks 987 and 254)
2013 San Deigo Regional Entrepreneurship Award
2012 Los Angeles Regional Semifinalists (Thanks 599, 3309)
2012 San Diego Regional Finalists (Thanks 399, 2339)
2011 Los Angeles Regional Chairman's Award
2011 BAE Regional Judges Award
Unread 01-04-2012, 12:06
AcesJames's Avatar
AcesJames AcesJames is offline
Mentor, still learning
AKA: James Temple
FRC #2170 (Titanium Tomahawks)(EWCP)
AcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond reputeAcesJames has a reputation beyond repute
Send a message via AIM to AcesJames Send a message via MSN to AcesJames
118 does in fact use a stinger. A lot of us at CT huddled around their pit on Thursday as we watched them re-attach their shooter, add 2 speed transmissions, swap their bridge mechanism, and add their stinger. It was quite a site to see (although I'm sure they can elaborate on that better than I can).
2168 (as far as I know) in their starting configuration is short enough to be able to drop their stinger on the opposite side of the field and still not reach the full 60". I believe that the 228 machine is a fair bit taller.
(09-12) - FRC 176 - Aces High
(13 - 14) - FRC 229 - Division By Zero
Clarkson University - 2016, Innovation and Entrepreneurship
Unread 01-04-2012, 12:17
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
Sorry, Michigan did had a triple balance with two stingers in Week 2 at Waterford (67 and 469).
http://www.flickr.com/photos/daniele...7629560227229/
-Clinton-
Unread 01-04-2012, 12:45
-Clinton-
I'm sorry if I wasn't clear- I meant both stingers deployed at the same time. From what I can remember at Waterford, only 67 deployed their stinger.
Unread 01-04-2012, 12:47
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
2168 looks like they may exceed 60" total height in this picture. In the linked image of 67/469 above it appears that 469 would definitely be taller than 60" if their stinger was deployed.
If you have a stinger that makes the entire vertical height of your robot greater than 60", can you deploy it on the lane-side of your bridge without incurring a foul? Manual seems to say no.
Originally Posted by G20
Robots in contact with the carpet and/or Key on their Alliance Station end of the Court are limited to 60 in tall. Otherwise, Robots are limited to 84 in tall.
Violation: Foul; or Technical-Foul for repeated or continuous violation.
Unread 01-04-2012, 12:57
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
-Clinton-
469 didn't have their "peg leg" at that point in time. They built it after seeing the success team 67 had.
Unread 01-04-2012, 13:22
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
228 and 177 both used their stingers in the first match of their elimination round. After our second triple, Dancing Dave asked to take a look at our height, we happened to be 64 inches tall. We had already deployed a strategy to just feed 177 balls in hybrid and teleop, so removing our shooter hood was an easy fix to put us within the 60 inch limit. I was very glad to be able to pull off the triple so quickly, with the double stingers it was almost easier than a single or double.
-D
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 01-04-2012, 13:57
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Sigh, 2168 has to be one of the best machines to not win a trip to the CMP this year. Gotta feel for those guys.
Also, if memory serves me, 2168's robot is under 4' tall in the starting config so assuming their stinger is 12" or less, they are still within the 60" height parameter. *Edit, see Josh's post below*
-Dustin Benedict
Unread 01-04-2012, 14:37
lnex1357's Avatar
lnex1357 lnex1357 is offline
Inspiration through Determination
AKA: Joshua Miller
FRC #2168 (Aluminum Falcons)
lnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud oflnex1357 has much to be proud of
Send a message via AIM to lnex1357
Smile Re: pic: Triple Balance 2 of 3: CT Regional
To clarify the discussion: After our first successful triple balance in QF 1-2, one of the referees called our total height with the stinger down into question and had the lead inspector measure us between QFs and SFs. It turns out we were beyond the 60" height restriction. Something we never thought to check and the inspector overlooked during a re-inspection, after the addition of our stinger during the practice day on Thursday. Hence you will notice during our second Triple Balance in SF 1-1 we balanced from our offensive zone side of the field. Fortunately for us it was just a simple adjustment to strategy and our whole alliance adjusted perfectly ... a great testament to all the teams and their drivers on the #1 seed alliance ... you guys are stars
Clarkson University 2010 / GENERAL DYNAMICS Engineer / EWCP / FIRST Volunteer
FRC Team 2168 - Aluminum Falcons, [2011-20xx]
FRC Team 229 - Division By Zero, [2004-2010]
"Desire is the key to motivation, but it's determination and commitment to an unrelenting pursuit of your goal - a commitment to excellence - that will enable you to attain the success you seek."
Unread 01-04-2012, 14:55
FF - PureMichigan
469 had their peg leg/stinger since Waterford but never had a need to use it. The redesigned it for Detroit, so that it would go out the back.
-Clinton-
Unread 01-04-2012, 15:07
nikeairmancurry's Avatar
nikeairmancurry nikeairmancurry is offline
FF - TeamSuperPowerMatic
AKA: Nicholas
FRC #0313
nikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond reputenikeairmancurry has a reputation beyond repute
469 had it off to the side at waterford and used it a few times going up the co-op bridge.
Team Member- 326 2006-2009
Team Mentor- 326 2010-2013
Team Mentor- 313/5220 2014-??
Unread 01-04-2012, 19:06
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
cj3958 will become famous soon enough
I believe the "transitional stage" allows you to be taller than 60" when you have a 'stinger' deployed. The head ref at boston talked to us about that and we were able to convince him otherwise; however its only a 3pt penalty even if you do violate the 60" rule.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
