Go to Post note to self: do not use robot to retrieve cars from water. - Greg Marra [more]
Unread 01-04-2012, 19:34
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
Re: pic: Triple Balance 2 of 3: CT Regional
Originally Posted by bam-bam View Post
I'm pretty sure they do now.
If you check below 118, you can see part of its bridge mechanism blocked by a head.
And something tells me that this is the first time there was two stingers in a triple balance.
Be careful of the Stingers. If you enter the ramp from the opposing side, you can't exceed the 5' rule, you are in violation. The 5' rule will be measured from the top of your robot to the lowest part of your robot...the bottom of the stinger. There was a 3 point penalty in CT on Saturday, but wasn't the 1st one to be a penalty at a regional. You CAN exceed the 5' rule on your own side of the field.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 01-04-2012, 19:36
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Originally Posted by MarcD79 View Post
There was a disqualification in CT on Saturday, but wasn't the 1st one to be disqualified at a regional.
I don't believe there was a disqualification because of the stingers, just a pair of fouls handed out to us and 2168.
-D
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
Unread 01-04-2012, 19:39
dsmoker's Avatar
dsmoker dsmoker is offline
Robo Mom
dsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud ofdsmoker has much to be proud of
Dave is right, there was no disqualification, but I believe the refs said a second violation would result in a yellow card and a third a DQ, so that in future matches it would not just a 3-point penalty, as someone earlier in this thread stated.
Denise Smoker, Mentor, Team #558, Elm City RoboSquad
Finalist, N.E. District Championshp 2014 (thanks 195 and 5122)
Judge's Award, N.E. District Championship 2014
Winner, Hartford District Event 2014 (thanks 177 and 5129)
Chairman's Award, Southington District Event 2014
Winners, Southington District Event 2014 (thanks 195 and 999)
Creativity Award, WPI Regional 2013
Finalist, CT Regional 2012 (thanks 1071 and 2067)
Engineering Inspiration Award, CT Regional 2010
Judge's Award, CT Regional 2009
Johnson & Johnson Gracious Professionalism Award, CT Regional 2008
Woodie Flowers Award (mentor Ernie Smoker), CT Regional 2008
Winner, CT Regional 2007 (thanks 195 & 1124)
Daimler-Chrysler Team Spirit Award, CT Regional 2007
Finalist, CT Regional 2006 (thanks 181 & 356)
Imagery Award, CT Regional 2005
Unread 01-04-2012, 19:41
MarcD79's Avatar
AKA: Marc
-D
I realized my mistake, it has been corrected 3 point penalty.
Mentor & Volunteer
Unread 01-04-2012, 19:51
davepowers's Avatar
AKA: Danger Dave
This is true, we were told it would be a yellow card the next time, and a DQ the time after that, which I was a little confused with because the manual states it would only be a Technical for repeated use.
Originally Posted by 2012 FRC Game Manual
[G20]
Robots in contact with the carpet and/or Key on their Alliance Station end of the Court are limited to 60 in tall. Otherwise, Robots are limited to 84 in tall.
Violation: Foul; or Technical-Foul for repeated or continuous violation.
-D
Unread 01-04-2012, 21:17
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
cj3958 will become famous soon enough
Now wouldn't that also make it illegal to go over the bumb if you were exactly 60" tall? If you think about it you could be potentiallt 64" tall and be on the opposite side of the feild, no? Also the intention of the 60" while on d-fence was that you weren't blocking shots, so if you dont block any shots because of your stinger then they should just not call the penalty.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
Unread 01-04-2012, 21:37
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
The Q&A makes this answer very clear:
Q. Please define "tall" verses "height" specified in ROBOT R02. Is "height" an absolute measurement from the carpeted floor of the arena whereas "tall" references the robot's height when only on the carpeted surface? Example: A 60" tall robot balanced on top of a 12" bridge is 72" in height. FRC1985 2012-01-12
A. The vertical measurement is always in relation to the Robot.
Regardless of the "spirit" of the rule, a rule means what it says. Until the GDC says otherwise, the 60" restriction stays.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 02-04-2012, 13:08
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
look at all those colson wheels.
Unread 02-04-2012, 15:08
nasamen3728's Avatar
nasamen3728 nasamen3728 is offline
FRC #3728 (Iron Panda)
nasamen3728 is an unknown quantity at this point
hey guy just asking who won CT Regional ???
Unread 02-04-2012, 15:14
Well, if you look at http://www2.usfirst.org/2012comp/Events/CT/awards.html (accessed by going to the FIRST site, FRC, Events->Regional/District Events, and choosing Connecticut), 195, 181, and 20 won the robot competition and 694 won the most prestigious award.
Unread 04-04-2012, 14:54
What an epic picture. All three such clean bots. Love it!
