Go to Post I got to talk with Mr. Flowers briefly last year. I told him that I had wanted to be part of FIRST since about 1980. It was nearly a quarter-century later when my son entered high school and I joined the TechnoKats as a mentor. - Alan Anderson [more]
Unread 01-04-2012, 00:08
rhp3794 rhp3794 is offline
rhp3794 is an unknown quantity at this point
Kinect Station
Hi guys, i´ve got a question...
how do you connect the kinect during competition
my team is going to compete next week, and im trying to figure how to connect from the drivers to the kinect station
is it by usb?
or wireless?
Programming Leader
Team 3794
WinT
Unread 01-04-2012, 00:09
Re: Kinect Station
also, do i have to download the kinect kiosk??
Programming Leader
Team 3794
WinT
Unread 01-04-2012, 00:19
Re: Kinect Station
There is a USB cable that runs into the driver's station. It doesn't matter which driver's station you're in, it'll reach.
Unread 01-04-2012, 01:23
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
Re: Kinect Station
There is a USB cable for each alliance on the field. Follow the steps here - http://www.usfirst.org/sites/default...o r%20FRC.pdf to get the kinect station working. It has everything that you will need to download
FRC Team 987 - It's not enough
Unread 01-04-2012, 07:39
DominickC DominickC is offline
FRC #0023 (PNTA)
Rookie Year: 1620
DominickC is an unknown quantity at this point
Re: Kinect Station
Also note that you do not need to run the Kinect Kiosk on your computer. There will be a classmate (or comparable laptop) which is connected to the Kinect, running the Kinect Kiosk.
At the WPI Regional, we were the only team to attempt to use the Kinect, and we noticed that the boxes which the Kinect was mounted in were angled away from the designated Kinect area. If you notice this before a match where you plan to use the Kinect, politely approach someone and ask if it can be fixed.
Unread 01-04-2012, 08:21
Re: Kinect Station
Just repeating what everyone else has been telling you.
As they said, there is a long Kinect USB cable that gets moved around between Driver Stations as teams need to use the field Kinect. Make sure you plug it into your Driver Station and test to be sure the Kinect is working with your laptop.
Inform the field crew that you will be using the Kinect so they can prepare, too.
There is a wooden case holding the Kinect at the corner of the field with a player area marked out on the floor. Inside the box is a high-end laptop that repeats the skeleton that your Driver Station receives from the Kinect.
That's what's running the Kinect Kiosk software.
The angle of the wooden box really doesn't matter. It can be crooked. What really matters is the direction that the Kinect is pointed. It's just sitting in the top of the box and the field crew can adjust it if necessary.
If your skeleton is centered on the screen and you can see all your arms/legs/heads, then the Kinect is aimed correctly.
Unread 01-04-2012, 21:59
Re: Kinect Station
Thanks guys!
Programming Leader
Team 3794
WinT
Unread 01-04-2012, 22:04
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Re: Kinect Station
I would also mention that in your pre-match strategy meetings you should inform your alliance partners that you are using Kinect, in case two or three members also use it. This way you can decide on who gets it. We had one such conflict at North Star. There's a low probability of a conflict occuring, but do this to make sure.
PLEASE notify field staff that you are using kinect, they will guide you through the process of setting it up. You must notify them, it isn't just plug and play.
Unread 04-04-2012, 19:29
pigpc1993 pigpc1993 is offline
AKA: Colin Feeney
FRC #3716 (WARP)
pigpc1993 is an unknown quantity at this point
Mark by repeating the skeleton you mean one you, the human player, can see?
Colin Feeney
Team 3716
Lead Programmer
Unread 04-04-2012, 20:34
Registered ConfUser
AKA: Mark McGivern
Re: Kinect Station
Yeah, the wireframe of joint vertices and the skeleton lines you see on the DS laptop screen on the Kinect tab is repeated on the Kinect station screen, readily visible by the Kinect operator. You'll also see some sliders for the value of Stick1 and Stick2 and some color level sliders.
Unread 04-04-2012, 20:35
Re: Kinect Station
Yes. Your Driver Station does all the work with the Kinect, but then the skeleton and joystick information is sent both to the robot and to what's essentially a repeater on the Kiosk computer just so the human player can see him or herself moving and being recognized by the Driver Station.
Unread 04-04-2012, 20:47
AKA: Colin Feeney
FRC #3716 (WARP)
Okay. That's what I thought. I was confused for a second.
Colin Feeney
Team 3716
Lead Programmer
Unread 05-04-2012, 18:06
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Kinect Station
Also feel comfortable informing (and reminding as necessary) the referee in that corner. Otherwise, we may accidentally move and obscure your view of your robot.
Unread 05-04-2012, 18:57
tyron256's Avatar
tyron256 tyron256 is offline
FRC #3008
tyron256 is an unknown quantity at this point
Re: Kinect Station
field crew also, they may walk in front of it by mistake or not move people out of the way fast enough. we had to replay a match at Hawaii because of it.
Unread 05-04-2012, 20:05
AKA: Colin Feeney
FRC #3716 (WARP)
Just ran into that issue with the ref blocking.
Colin Feeney
Team 3716
Lead Programmer
