Go to Post FIRST is all about going past theoretical limits. - Foster [more]
Unread 01-04-2012, 22:15
MAldridge's Avatar
MAldridge MAldridge is offline
Lead Programmer
AKA: Rube #1
FRC #0418 (LASA Robotics)
MAldridge will become famous soon enoughMAldridge will become famous soon enough
Re: Variables, Cameras, and Wait
This is my solution to the toggle (see attached). At some point, I will do a write up on the advantages of doing it this way. Essentially, you put 'Grand Unified Button Handler' in your periodic tasks in a 15Hz loop and read your joysticks into it there; then you pull the outputs into a global and read the global wherever you need it. In the GRUB main vi, there is a control labeled 'latched?' you set which ones are latchable and then you set current as default, that way you can quickly change a button from latching to non-latching without rewriting large sections of code.
'Why are you a programer?' --Team Captain
'Because the robot isn't complicated enough!' --Me
