Go to Post GP is a much longer-term investment, yet offers surprisingly high returns. Just like 401(k) plans, the important thing is to keep making contributions even when it seems there's no reward for it. - ayeckley [more]
Unread 02-04-2012, 11:13
Ornocarbo Ornocarbo is offline
Ornocarbo
AKA: Josiah
FRC #2508 (Armada)
Ornocarbo is an unknown quantity at this point
Send a message via Yahoo to Ornocarbo
Autonomous balls getting stuck
Our team recently competed at the 10,000 lakes regional in minnesota and we performed very well. However at the last semi-final rounds during the autonomous period our dumper system which dumps two balls into the lower basket got the balls stuck in the hoop. The system worked fine all the other rounds up until we needed it most. We bagged it up to be ready for state competition invites already so we can only change the program for it. Would increasing the dump speed change anything? or is it just plain bad luck?
Unread 02-04-2012, 11:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Autonomous balls getting stuck
You probably want to increase the time interval between when each ball is scored. This will give the 1st ball time to clear out before the 2nd ball is introduced. We ran into a similar issue.
Unread 02-04-2012, 12:02
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
During one of the matches in elimination rounds at the Livonia District this past weekend, 3 balls got stuck in the top basket during Hybrid. Since they could not free the balls before Hybrid ended, they stopped the match due to a field fault and reset the field. I have also seen it happen where balls got stuck during Hybrid and they allowed the match to continue without giving the Hybrid bonus.
Unread 02-04-2012, 13:14
Dr Theta's Avatar
Dr Theta Dr Theta is offline
Lead Mentor
AKA: Derek Messer
FRC #2232 (Deus Ex Machina)
Dr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud ofDr Theta has much to be proud of
At the event in question the field techs unjammed the balls and altered the score during the teleop period to reflect that the balls were scored in hybrid mode. All your points were accounted for they just weren't up there immediately.
Unread 02-04-2012, 13:18
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
At Northville they were using a long pole to poke the balls if they got stuck in the hoop. It worked pretty well.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
NickTosta NickTosta is offline
Team 195 Alumni & Former Driver
no team (The Cyber Knights)
NickTosta is an unknown quantity at this point
Originally Posted by Dr Theta View Post
At the event in question the field techs unjammed the balls and altered the score during the teleop period to reflect that the balls were scored in hybrid mode. All you points were accounted for they just weren't up there immediately.
Yeah, if the balls need to be cleared manually during tele-op the points will be added either during tele-op or after the match is over. As far as I know every regional has done this.
I'd say that if your autonomous program is fast enough to get balls clogged in the hoop your autonomous program is working very, very well. Don't go changing it unless you start missing, because they'll always give you the points sooner or later.
Unread 02-04-2012, 13:22
JosephC's Avatar
At Waterford 2 balls got stuck in the top hoop next to each other. We launched a 3rd ball into the hoop and it bounced out, and even though it was an obvious basket, it wasn't counted. Those 6 points cost us the match (We lost by 4 I believe.)
Referee: 2015 - ?
mdaniel462's Avatar
mdaniel462 mdaniel462 is offline
FRC #3322
mdaniel462 is an unknown quantity at this point
This happened to us in Livonia. I think we had 5 balls stuck and a 6th ball bounced out after hitting the jam. From what I can gather from CD is that a field fault is only generated if a ball that probably would have gone in, doesn't because of a ball jam.
________________________________________
Matt RD
Team 3322, Eagle Imperium
Mechanical Design Mentor
Unread 02-04-2012, 13:23
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
At Palmetto we clogged the top basket during hybrid in a quarter final. It was a minute or so into the regular match before they were able to unclog the basket with a pole. They award the points to the hybrid period.
Unread 02-04-2012, 13:27
JosephC's Avatar
Did they reset the match? That seems like a major field fault; if your opponent was able to score and you weren't they should have reset the match.
Referee: 2015 - ?
Unread 02-04-2012, 13:33
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Everything I've read says that that should have lead to the match being restarted. Did you complain at all?
Does anyone else remember when TBA signatures actually worked?
Unread 02-04-2012, 13:49
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
I'd think both alliances would have a beef here. The alliance with the jammed goal has lost their favorite place to score, and the other alliance has not been able to send those jammed balls back to the other side to be scored. These inconviences are not equal or offsetting in my opinion.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
Unread 02-04-2012, 15:31
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
You can see the stuck balls in the link below:
http://525swartdogs.org/pages/Match_...sota_2012.html
Also, there is neat shot in the same match at the 1:32 mark on the red alliance side of the field. A ball briefly sits on top of the backboard and then falls through the hoop.
