Go to Post How are you planning to teleport balls? Or your robot? I was pretty sure that the battery couldn't supply the required power draw. - RoboChair [more]
Unread 07-01-2003, 23:12
Funny Funny is offline
#0159 (Alpine Robotics)
Team Role: Student
Funny is an unknown quantity at this point
Send a message via AIM to Funny
Basically, a bin all by itself, in any rotation, is counted as a multiplier of one. Basically, a stack will essentially be counted by the number of bins in it, no matter if they are nested or not.
So, if you have a bin that is like 1.1 SHUs, it is just counted as 1 for a multiplier. Same if the bin is 1.9 SHUs.
Unread 07-01-2003, 23:15
Originally posted by M. Krass
That is, assuming that you can't have a stack of zero whilst there are bins in your scoring zone.
<14.75" = 1
14.75"-29.50" = 2
29.50"-44.25" = 3
etc.
saying that
<14.75" = 0
14.75"-29.50" = 1
29.50"-44.25" = 2
etc.
also means that you can't have a stack of 0, becasue there is no orientation of a box (except broken) that is less then 14.75"
Unread 07-01-2003, 23:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally posted by Joe Ross
saying that
<14.75" = 0
14.75"-29.50" = 1
29.50"-44.25" = 2
etc.
I never knew broken was a kind of orientation.
Down to business here, all we really need confirmed is if the SHU measuring stick starts with 0 SHU or 1 SHU
Unread 07-01-2003, 23:27
Team Role: Student
Simply out, Joe must be right. If a box in normal upright orientation was two SHUs, the whole system would collapse...
and my head would explode and the world would end... well maybe not that last part.
Unread 07-01-2003, 23:28
p373R L1a0 p373R L1a0 is offline
#0254 (Cheesy Poofs)
p373R L1a0 is an unknown quantity at this point
I think what originally was said during the kickoff that it is like this
=2
=1 |==== |<<-Bin on side extends into the 2 scoring ||\=====/ | | zone, hence it counts for 2
|| \___/ |_____|
However, now the rules have changed so it rounds DOWN. in the team update this is underlined in bold. its my own intuition, so i would say that it indicates an important change. who knows, sanddrag may be right
Unread 07-01-2003, 23:32
=2
||\=====/ |--------| zone, hence it counts for 2
|| \___/ |_____|
SOrry.. other one was messed up
Unread 07-01-2003, 23:34
seisenberg seisenberg is offline
#0006 (CogSquad)
seisenberg is an unknown quantity at this point
Unless they had a total about-face, the bottom of the stick starts at 1.
That way, a normal right side up bin reaches to just below the "2" line, a tipped bin scores 2.2, rounded to 2 as per Team Update #1, and everthing is as Woody said.
Otherwise they're nuts
Unread 07-01-2003, 23:45
obviously here, the debate is over whether or not the measuring stick starts at zero or one. im not sure, and i dont have a tape of the kickoff with me . in the team update, it was underlined in bold (signifying a change?), so i donno :/
Unread 07-01-2003, 23:49
Teedoff101 Teedoff101 is offline
#0992 (Oakwood Robotics)
Teedoff101 is an unknown quantity at this point
Here's how it works as Woody said it. The stick starts out at 0'. When u put the first bin in the normal position it counts as one. If the second bin (or any number higher than that) is place upside down, that would go over the next line and what would've been a multiplier of 2 (using this example. could be any amount of boxes) is now a multiplier of 3. In the update, it states that if a box is placed upside down it wont affect the multiplier because it has been rounded down. So 2 boxes (1 face up, 1 face down) counts as a multiplier of 2, not 3. Woody's way was to round up if any part of the box was above the nearest hash mark on the measuring stick. I hope this clears things up. All the update does is make the scoring the opposite way that Woody said. No more is there the strategy of placing the boxes upside down and getting a 1 higher multiplier. Teams, rethink your strategies!
Unread 07-01-2003, 23:54
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
You keep saying you are unsure if there was a change to the rule...
There Was!
Read the original rules, then read the update. The SHU height has been lowered by 1" and the system now rounds down.
5
4
3
Unread 08-01-2003, 00:01
There Was!
5
4
3
Gadget, you left out the zero level. It should look like this
5------
4------
3------
2------
1------
0------ <<floor level
The height of one bin in standard position would be one inch above 1 SHU.
Unread 08-01-2003, 00:04
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
Like everyone else, I thought I heard Woody say that a turned up crate got you an extra SHU....
But now that I think about it, did he ever actually say that it scored the extra SHU? Or, was it more like "Notice that a crate on its side moves you into the next SHU".
Maybe his point was that if you stack enough crates on their sides (or ends), then you can eventually gain an extra SHU (I'm not bothing to do any calculation right now, so I don't know the right number)...
Just seems like the kind of challenge Woody would tend to throw out there.
Just my two cents...
Aidan
Unread 08-01-2003, 00:10
That is correct according to the stick starting at 0 SHUs at floor level and rounding down. I believe Woody's explanation was wrong. (note 1 SHU =14.75" and 1 bin in standard position is 15.75" tall. 1 SHU = the height of a nested bin)
Unread 08-01-2003, 00:42
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Here's my midnight math...
1 bin = 1 SHU = cannot extend into 2nd SHU
1 bin turned on end = does extend into 2nd SHU = 2 SHU's = 2.25 bins high
2 bins stacked neatly = 2 SHU's = Does not extend into 3rd SHU
2 bins top to bottom or WHATEVER = extends into 3rd SHU = 3.145 bins high = 3 SHU's
PLEASE Round 3.145 down..... I get 3 not 2
A glass even marginally, filled is a glass.
This is the way woodie explained at kickoff
NOW... (direct from the update)
Its height is measured in whole Stack Height Units (SHU) as described previously in Section 7.6. WHOLE SHU's. Sounds like you have to fill the SHU.
ONLY a full glass, is a glass.
We took something that made sense to all of us & made it confusing.
Unread 08-01-2003, 00:47
I don't think you're helping with the glasses.
Anywhoo, you talk about the SHU as if it were a space when I think it is only a mark, like on a ruler.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
