Go to Post Scientists ask Why, Engineers ask Why not. - Rohith Surampudi [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-01-2003, 00:47
kbmeister kbmeister is offline
#0971 (Spartan Robotics)
kbmeister is an unknown quantity at this point
Send a message via AIM to kbmeister
Question The Exotic Materials List
I'm very confused here. According to rule K2, "If a part category does not list the part you wish to use, then it is not allowed." Now this should include the Exotic Materials list too... However, this leaves the question: Is there anything else not explicitly included in the list that is considered "exotic", and if so, where is the boundary?
Then I refer to the Part Use Flowchart, where it states indirectly that, if an item is not listed under the Exotic Materials list, and it is not otherwise prohibited, then it is allowed.
It seems to me that this section is handled differently from the rest of the restricted materials list, and that essentially, any material not explicitly listed as exotic is allowed, or else we are to assume that only those materials listed are considered exotic.
Eagles may soar, but weasels don't get sucked into jet engines.
Unread 08-01-2003, 02:37
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
If you look at the restricted parts list there are 5 categories: "Electronics", "Energy Sources", "Exotic Materials", "Pneumatics", "Springs", "Traction".
Now, let's take Steel as an example. It's not an electronics component. It's not an energy source. It's not an exotic matierial. It's not pneumatics. It's not a spring. It's not being used as a traction device. Therefore, you can use it.
I know, the Restrited Parts List is quite redundant. Many of the things it lists are already outlined in the rules section. Basically, if it falls under any of the categories, and it isn't listed in that category, it can't be used. If it doesn't fall under any of the categories, then you can use/buy it. Just keep in mind that you have to stay under the $3500 robot cost.
If you look under rule K2, they give some examples that might help you understand it better.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
Team list & Events archiver 2000 2 23-06-2002 22:39
Suggested list of things to bring to the regionals Andrew Wyatt Technical Discussion 1 06-03-2002 14:41
Conveyor Belts Pengiun Joe Off-Season Events 2 02-11-2001 22:49
Additional allowed materials kmcclary Off-Season Events 3 11-10-2001 13:05
