Go to Post I believe with every fiber of my being that Engineering is an Art. It is a beautiful, wonderful, delightful art. - Joe Johnson [more]
Unread 03-04-2012, 08:06
chuckmerja chuckmerja is offline
FRC #1696 (RoboRevolution)
chuckmerja is an unknown quantity at this point
homemade encoder issues
we are having some issues while trying to make a single channel encoder using an NTE3100 <http://www.nteinc.com/specs/3100to3199/pdf/nte3100.pdf>. We think we have biased the 3100 thusly (we have tried with and without the 1 meg resistor)... <http://home.pacifier.com/~mcginty/nte3100.htm>
|+5VDC |+5VDC
\ \ Both Resistors
/ / 1 K ohm
\ \ Brown, Black, Red
/| <-v
Signal out----+------+ +----+
/ 1 Mega Ohm |
\ Brown, Black |
/ Green |
__|__ __|__
___ ___
_ _
We get 4.95 V when high (unblocked), but only drop a volt to about 3.8 V, so we never go low.
We are hooked to a "digital sidecar" and cRio. <http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2012_Assets/Digital%20Sidecar.pdf> <http://www.ni.com/compactrio/>
Any help would be greatly appreciated.
Thanks, Chuck.
2005 - Sacto quarterfinalist
2006 - Sil Valley quarterfinalist
2007 - AZ semifinalist, 2 judges awards, Woodie Flowers Award
2008 - smallest team from smallest school in FIRST - 3 person team!! - Seattle semifinalist
2009 - let's just say this bot would not have qualified for a trip to Mars
2010 - redoubled quality effort - won quality award and WINNER Utah Regional (first MT team to win an FRC regional) also won state FTC tourney (team 724)
2011 - Finalist UTAH regional
Unread 03-04-2012, 11:16
DonRotolo's Avatar
Back to humble
FRC #0832
Re: homemade encoder issues
I'm thinking that your grounding resistor of 1M is too high, and so the phototransistor's leakage current is raising your Voff very high (3.8V). Try 10k or 100k on the bottom and see what happens.
Unread 03-04-2012, 11:48
According to the datasheet, the NTE3100 has an NPN phototransistor. If that's the case, Brian McGinty has connected it very oddly.
Try connecting the "bottom" of the detector to ground (the "-" pin on a Digital Sidecar's DIO connector) and use the "top" of the detector for the output (the "SIG" pin). The Digital Sidecar's internal pullup resistor will give you a false reading when the sensor is illuminated, and a true reading when the LED is blocked.
