Go to Post Our safety manager isn't allowed to use the power tools, because he used a drill as a pointing device. - daniel_dsouza [more]
Unread 10-02-2012, 09:43
dominique dominique is offline
FTC #0211 (MK211)
dominique is an unknown quantity at this point
Access to WPIImages and IPLImages
We are using SmartDashboard to view and process the images from the camera.
We have access to a WPIColorImage. Unfortunately, when we isolate the blue, red and green channel as per examples given, the detection of rectangles of a specific color (around the hoop) is erratic.
So I thougt of using HSL space to isolate specific colors but this can be done only from an IPLImage.
Paul indicated here a way to access the underneath IPLImage using a java wrapper.
http://www.chiefdelphi.com/forums/sh...ferrerid=46078
Now I have access to the IPLImage but my detection still does not work as expected - I need to see the IPLImage and check what I am doing. Anybody knows how to obtain the WPIImage from an IPLImage ? Thanks.
Unread 13-02-2012, 15:28
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: Access to WPIImages and IPLImages
The following code fragments demonstrate going both directions:
public WPIImage processImage(WPIColorImage colorImg) {
  // Example of getting access to the underlying IplImage of a WPIImage
  WPIImageWrapper wrapper = new WPIImageWrapper(colorImg);
  IplImage iplImage = wrapper.getIplImage();
  // Example of getting the BufferedImage from a IplImage and constructing
  // a new WPIColorImage
  WPIColorImage newColorImg = new WPIColorImage(iplImage.getBufferedImage());
  return newColorImg;
Unread 13-02-2012, 15:32
Jared Russell's Avatar
Taking a year (mostly) off
This is essentially what we did, and it works great.
Unread 15-02-2012, 10:12
nickpeq nickpeq is offline
Turing-complete
FRC #1255 (Blarglefish)
nickpeq is an unknown quantity at this point
I understood how to do vision processing on the cRIO and our program is very good at recognizing the target using HSL color space. However, I know next to nothing about programming SmartDashboard extensions with WPI/javacv libraries. Does anyone have example code on using HSL color space with vision processing through SmartDashboard?
Unread 23-02-2012, 20:12
Turing-complete
Sorry to bump, but I know that someone has a solution and may have just missed this thread/post. Can anyone please give an example of how to track using HSL color space on SmartDashboard?
Unread 03-04-2012, 18:13
pequnp pequnp is offline
FRC #1477
pequnp is an unknown quantity at this point
For accessing SmartDashboard, just extend the WPICameraExtension class provided in the jar in the SmartDashboard extensions directory.
Then just override the processImage(WPIColorImage rawImage) method. The only real change you'll need to make code wise is to figure how you want to output the data to SD. When you're done, compile your widget into a jar and place it in the extensions directory. I'm sorry, but I don't have good example code of this.
Unread 01-05-2012, 12:53
notmattlythgoe's Avatar
notmattlythgoe notmattlythgoe is online now
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
I'm working on improving our vision processing over the off season. I'm trying to create a grid of images to display but I can't figure out how to get the BufferedImage converted back into a WPIImage. It compiles but throws this error when I try to build it.
cannot access com.googlecode.javacv.cpp.opencv_core
class file for com.googlecode.javacv.cpp.opencv_core not found
return new WPIColorImage(img);
Unread 03-05-2012, 13:41
Flywheel Police
I got the last problem figured out but have run into another problem. I am having problems with getting the IplImage out of a WPIImage. When I try to access the image field variable it tells me that it has protected access. What is the work around for this?
Unread 03-05-2012, 15:46
What we did here is make a static helper class that lives within the same package namespace as the WPIJavaCV classes with methods to expose the protected member variables (since protected members are visible to all classes within the same package).
Unread 04-05-2012, 09:10
Flywheel Police
Thanks, I had been looking at your code and missed the package line. Makes sense now.
