Go to Post Lexan $20.... Stock Aluminum $30.... Having a OI that is heavier than the robot PRICELESS.... - GBIT [more]
Unread 03-04-2012, 12:13
kellymc kellymc is offline
FRC #0766 (Bears)
kellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to beholdkellymc is a splendid one to behold
Digital Sidecar 5 volt regulator blow
Somehow we managed to fry the 5v regulator on the digital sidecar, can someone take a picture of the digital sidecar showing the chips so we can try to repair ours since AM is out of stock, we would like to have a spare digital sidecar for the championships.
Kelly
Unread 03-04-2012, 12:22
Re: Digital Sidecar 5 volt regulator blow
Those supplies will "play dead" if their output is shorted. Sometimes the board will spring back to life once you clear the short.
If it is actually dead, do you know what caused it?
Here is the link to the design files: http://www.usfirst.org/roboticsprogr...stem-resources
Unread 03-04-2012, 18:28
FRC #0766 (Bears)
Re: Digital Sidecar 5 volt regulator blown
It's definitely gone, we opened the case and there's half a chip left, I'm not sure what happened, I just know it did
Thanks for the link, the diagrams show are for Rev. 7, the 2012 sidecar has a Rev.8 pcb and the component we blew is not shown in the Rev.7 diagrams. Anyone know where we can find the layout for the Rev. 8 pcb. The component that we blew is just to the right of the smiling sun, it is a surface mount IC with 8 contacts.
Kelly
Unread 03-04-2012, 19:00
Here's Rev 8
Unread 03-04-2012, 19:05
FRC #0766 (Bears)
Thanks, I'll post if we were successful in reviving the sidecar
Originally Posted by Mark McLeod View Post
Here's Rev 8
Unread 03-04-2012, 19:07
They should be nearly identical, especially that circuit. You can petition FRCHQ to post the correct schematics - I've tried several times and failed. They were posted correctly last year, but this year's schematic regressed a bit.
It is a TPS5431 or TSP5430 if I recall correctly. The parts are pretty much identical except for maximum input voltage, so the manufacturer selects each year based on availability.
I'd love to see a photo of what happened. I'm specifically interested to know whether Q1 or U7 were also damaged.
I'm a bit confused though - you indicated that your 5V rail was damaged, but that U3 was the one that is missing pieces of itself? That should have taken out the 6V rail instead...
Unread 03-04-2012, 19:15
FRC #0766 (Bears)
Here's a picture, Q1 is blown
Unread 03-04-2012, 19:27
There is very little smoke damage but this could have occurred with a gate to source short. It could also be a crush break. Eric, have you seen this type of damage with a voltage reversal?
Unread 03-04-2012, 19:38
Thanks Mark!
Kelly - Q1 normally provides protection against reversed power. A huge pulse of current can damage it in the way shown. This could be the result of a chassis fault (motor current returning through the DSC), or from wiring the power backwards coupled with an ESD event (ESD can blow the gate and disable the protection).
Note: This may be a mildly dangerous repair. Please test with a bench top supply limited to less than half an amp, and keep an eye on the current draw. Testing with an FRC battery runs the risk of a small fire. On occasion I've had parts blow off the board while testing similar faults, but that only happens when I've bypassed at least one more layer of protection.
Before going through the effort of desoldering Q1, try shorting around it by plugging power into the usual connector and power return into one of the PWM power return lines. If it comes up correctly, replace Q1 and throw it on a non-competition bot. Otherwise, it may be irreparable.
Unread 03-04-2012, 19:40
Yep, usually in combination with an ESD event. One of the tests I performed in the lab was to apply reverse voltage and then hit the power line with 30kV from an ESD gun. Q1 would normally pop like Kelly's picture.
Unread 03-04-2012, 22:38
Brant Bowen Brant Bowen is offline
no team (AndyMark, Inc.)
Brant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant futureBrant Bowen has a brilliant future
Send a message via AIM to Brant Bowen
Kelly
I expect us to have the Digital Sidecars in by early next week, if not this Friday. Just FYI so you know you can get a new one for champs if you need it.
Operations Manager - AndyMark Inc.
Co-Volunteer Coordinator - Boilermaker Regional, Crossroads Regional, Indiana Robotics Invitational
