Go to Post You don't have to build a robot to be on a robot team. This isn't about the robot, it's about learning. - engunneer [more]
Go Back   Chief Delphi > Technical > CAD
Unread 03-04-2012, 21:09
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
Re: Custom Transmission - #1
Could you provide a pic of the internals, it's hard to say much just seeing the plates.
Consider how you are mounting the gearbox. Having that angle on the bottom won't help and I don't see any mounting holes already.
It doesn't seem to be a shifting transmission in which case it can be a lot thiner.
You should also reconsider your uses of a 17 tooth gear, I don't know where you plan to get it but something like 16 teeth is much more common.
Tristan has a good point, what benefit does this have over an andymark product? If your goal is to make something smaller/lighter than you could start with toughbox gearing and go from there.
