Go to Post The propagation of the idea of making FIRST into a perfectly fair competition is just silly. - Andy Baker [more]
Unread 14-03-2012, 11:20
MrRoboSteve MrRoboSteve is offline
AKA: Steve Peterson
FRC #3081 (Kennedy RoboEagles)
MrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond reputeMrRoboSteve has a reputation beyond repute
Jaguar brake/coast behavior / ramp mode question
1. Our team is interested in how the brake/coast setting on the Jaguars work.
We removed the brake/coast jumpers from the two Jaguars controlling our drive train and there wasn't a noticeable difference in behavior. The Jags are controlled via PWM.
The documentation we found isn't very specific about what the brake/coast setting actually does. Can anyone point us to a specific discussion on how the Jag's behavior changes in these two modes?
2. Is there a reason why a team would select the ramp mode on the Jag when controlling drive train motors?
Steve
Unread 14-03-2012, 12:04
Re: Jaguar brake/coast behavior / ramp mode question
You don't remove the jumpers. You move them. From brake to coast, or vice versa.
See attached diagram.
Name:	brake coast jumper.png
Unread 14-03-2012, 15:27
Steve,
With simple DC motors of the type used on the robot, the momentum of the moving robot actually causes the motors to become generators. The "brake" mode on either type of speed controller, essentially causes a shorted resistance to be placed across this generator. The result is that the current flowing in the short produces a force which opposes the motor rotation. When the motor is not moving, the brake mode has no effect.
Unread 04-04-2012, 02:21
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Is it the same way with Victors? At our last competition we switched out our jags with victors and after switching the programming we now coast instead of brake. Is there a jumper on the victor that we need to move?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 04-04-2012, 07:32
The Victors have the same jumper on the lower left
