pic: Two bot side balance
Re: pic: Two bot side balance
It's pictures like these that make me question Newtonian physics...the one that makes me question it even more is the Robotnauts "illegal" but ingenius bridge device.
How is this legit but 118's machine was not? There appears to be a mechanical device under that robot that straddles the bridge angle.
It straddles the angle, but it will likely only react against one side at a time. The part on the outside of the angle appears to just act as a stabilizer since they can't balance on a row of wheels alone. They are just resting on the bridge while occupying the smallest footprint possible as a result of a cleverly placed center of gravity; making it much more like Swampthing than 118's robot, Endeavor.
Edit: and now VB3 gives me the option to modify my previous post, how convenient ![]() |
This is clearly illegal. Physics does not support a scenario in which that robot can remain on the bridge without applying force to both sides of the angle, unless the CG remains over the bridge surface, which is highly improbable.
Cannot believe this was allowed to compete after 118 was denied. |
#7
Wow. 2 things:
1. Creative design 3534. Many teams thought of devices like this to aid in balancing either with 1 or 2 other robots, but.... 2. If this device is not just a CG tweak it would be clearly illegal. 118 amongst other teams (ourselves included) would be utilizing a side hanging device that accomplishes the same effect had it not been ruled illegal before the first qualification day of the week 1 regionals. -Brando Last edited by Brandon Holley : 04-04-2012 at 14:17. |
#9
EDIT: From this image, it appears that the side over the bridge is considerably more dense than the other side, including solid aluminum (steel?) blocks being used as ballast, so the possibility of an extremely biased CoG is possible. However, it also appears that there is a metal piece under the robot touching the side of the bridge. I can't tell if it's just used for allignment or if it reacts against the bridge. ![]() Last edited by smistthegreat : 04-04-2012 at 14:11. |
#10
If that's nothing more than a CG trick, that's just awesome.
#13
What I heard and observed from being at the competition is that 3534's center of gravity is indeed over the bridge when it does its side hang.
I don't have that hard a time believing this one wasn't ruled illegal, though... This one looks to basically be sitting on the bridge. 118 looked to be hanging off the side. So much of how the GDC ends up ruling things is based off how the solution looks. If they see something they don't like, it seems like they then figure out how to rule it illegal... * sigh * EDIT: Wow, if that really is true about the robot being designed so it's CG is in the 8" on the bridge-side of the robot, that is simply incredible! Congratulations! Even if it is illegal, I'd still say congratulations on accomplishing it - I would wish it (and 118's hanger) were legal! Last edited by Nathan Streeter : 04-04-2012 at 14:23. Reason: Sounds like it does indeed have its CG over the bridge... Wow! |
#15
Given that the robot was able to drive up the bridge (I'm assuming from the other photos that it made it up under it's own power), there must be enough weight over the drive wheels for it to power itself up, in which case grappling the lip is not necessary to stay on the bridge. I highly doubt you would be able to drive a robot up the bridge if it relies on clamping force on the lip to keep it from falling off. I'm curious as to how the friction from the portion of the robot touching the lip did not inhibit it from driving up though.
Doesn't look "clearly illegal" to me. Congrats to 3534 for creating and carrying out this design! Out of the box approaches are risky but oh so cool. Last edited by s_forbes : 04-04-2012 at 14:22. |
