Go to Post I can't claim to be an expert in the stess analysis field - I just play one on TV, er CD, er - okay, so call me a poser! - petek [more]
Unread 08-01-2003, 09:09
jmo8605's Avatar
jmo8605 jmo8605 is offline
jmo8605 is an unknown quantity at this point
Send a message via AIM to jmo8605
also the right motor will me able to throw the boxes and then u can control the speed which will also contorl the distance. jus make sure its fast and powerful
Jon
Unread 08-01-2003, 09:47
Martin Martin is offline
#0907 (East York Cybernetics Core)
Martin is an unknown quantity at this point
Send a message via ICQ to Martin
even tho...
even tho the box probably would not break...chances are the lid may come off...and the rules specify that you cannot remove lids...i assume since it was you that launched the box, it would also be you for removing the lid...
question: what if two robots are on opposite ends of the container, pushing towards eachother...chances are the lid might pop off..what then ?
thanks
2002 - 3rd seed
2002 - highest rookie seed award
2002 - J&J sportmanship award
Martin
907
Unread 08-01-2003, 09:51
jmo8605's Avatar
i have thrown the boxes at walls the tops have yet to come off so i dont think it is goin to easily come off.
thats a good question, both teams would prob. be penalized or it would be up to the judges. just a guess
Jon
Unread 08-01-2003, 13:07
Mike537Strategy Mike537Strategy is offline
#0537 (Charger Robotics)
Mike537Strategy is an unknown quantity at this point
Does no one remember that during the competitions the box lids will be bolted on with those special bolt things? I think that'll pretty much prevent the whole lid from coming off.
"Charging into the future, one game at a time." - Team 537 motto
Unread 08-01-2003, 13:11
D.J. Fluck
Posts: n/a
Even with the rivets on the lids, it will only hold for so long.
Unread 08-01-2003, 17:09
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
DA1 A referee may disable a robot that has damaged the playing field, barriers, containers or
another robot, if the referee feels that further damage is likely to occur.
If you are launching containers and one gets broken, the referee may use this rule, because if one broke from launching another might break later.
Unread 08-01-2003, 17:38
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
S10: The storage containers are the only projectiles that may be launched by a robot.
DA1: A referee may disable a robot that has damaged the playing field, barriers, containers or
another robot, if the referee feels that further damage is likely to occur. The referees may
require a corrective action, such as eliminating a sharp edge, before the robot will be
allowed to compete in subsequent matches.
The manual explicitly states that it is legal for a robot to launch containers. The lids are rivited shut, and should therefore not come off.
You can launch the container so long as the launch itself does not damage the container. If the subsequent impact damages the container it is the robot that has damaged the containers. This would therefor be legal.
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Unread 08-01-2003, 19:50
D.J. Fluck
Posts: n/a
Still, the rivets WILL break off eventually if the main part of the box survives the torture of the game
Unread 09-01-2003, 04:00
Clanat Clanat is offline
Custom Title
#0753 (High Desert Droids)
Clanat has a little shameless behaviour in the past
I don't see launching boxes as an effective strategy, it doesn't seem like with the weight you could launch one fast/far enough to make a difference.
Unread 10-01-2003, 00:14
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
I've calculated the physics for it. There are multiple ways of getting the speed needed. A 12 inch pneumatic with a 2 inch bore is easily enough to launch them 15 feet. My physics(well natures but hmph) called for a 1 foot arc that applies 90 pounds of force to the throwing arm in .06 seconds. My robot design uses a slightly different design but the physics works out that even a 6 inch in length pneumatic would provide more than twice the power needed to throw a crate 30 feet. I added in a feature that while you swing the crate(s) you extend your throwing mechanism. That lowers the force requried to get the speed up. Also using the battery to act as a counter weight on a seesaw like device was also thought of. I don't know if the first judges would allow that idea though. (using a 1 foot bar with the 20 pound battery allows you only need to use a 6 inch pneumatic witha 3/4 inch bore)
*as a note my entire team is against throwing in the autonomous period. We are sure that if we throw a crate the wrong way and it goes into the crowd bad things will come from the refs. very bad things. I guess testing would be in order for that ^_^
Team Website
Unread 10-01-2003, 01:06
Doug's Avatar
Doug Doug is offline
#0122 (Nasa Knights)
Doug is an unknown quantity at this point
Originally posted by jmo8605
just make sure its fast and powerful
Jon
yeah i think thats basically the idea behind all of our robots its sometimes easier said then done
yeah sorry i dont beleive in punctuation
122's stacking machine
Unread 10-01-2003, 04:58
Da Moose! Da Moose! is offline
Da Moose! is an unknown quantity at this point
Talking oooo, awwwwww, ooooooo
i would LOVE to see a barrage of boxes flying everywhere, but it might not be a barrage, but i would just love to see some boxes flying no matter what the outcome, just as long as nobody gets hurt. i would have liked to has tossed boxes, but we have decided against it.
Unread 10-01-2003, 10:40
MRL180YTL2002's Avatar
MRL180YTL2002 MRL180YTL2002 is offline
Post-A-Holic
#0180 (S.P.A.M.)
MRL180YTL2002 is an unknown quantity at this point
read rule 9.1. S10 in the Competion rules I believe states "The storage containers are the only projectiles that may be launched by a robot" therefore it comes down to whether the referees with disqualify you...like if a box gets launched into the crowd or causes damage to the field. The CIM motors if you looked last year a Woody's ball launchers has the power as do the Fisher Price and Bosuch Drill Motors have the power. This also conflicts with the drivetrain....we're already considered two penumatic clyinders for the drivetrains as well as the optical sensors, the CIM motors, and the drill motors.
Unread 14-01-2003, 23:42
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
About using pnuematic launchers, remember that big cylinders use a lot of your pressure. If you plan on launching boxes one of your main goals, you want to do it more than once every 30 seconds. You're better off just using a motor with an arm on a pivot or something like that.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 15-01-2003, 21:09
Post-A-Holic
#0180 (S.P.A.M.)
and the pump weighs like 4 pounds give or take a few ounces.
Dimensions of the kit boxes Jean McAuliffe General Forum 2 24-06-2003 00:40
Box throwing Anarkissed General Forum 33 19-01-2003 23:19
breaking boxes illumanat'i Rules/Strategy 6 19-01-2003 15:44
question on launching boxes 2PI4Julia Rules/Strategy 4 18-01-2003 10:17
plastic boxes Suzy General Forum 6 12-01-2003 03:27
