Go to Post Remember to have fun! That's what the FIRST experience should be for you- a lot of fun while doing a lot of learning. - smurfgirl [more]
Unread 07-01-2003, 21:04
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
Machining/Engineering Question
whats is the formula to find the PD (Pitch Diameter) of a 1/4 42 NS2B thread???
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
Unread 07-01-2003, 22:26
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
I can find out tomorrow or if you have a Machinery Handbook it would be in there. (Don't have mine with me)
If you are just looking for a tap drill size there is a simple *Rule of thumb* formula that works quite well
Major Dia - (1/TPI)=tap drill size about 70% thread
example 3/8-16
.375-(1/16)=.3125 or 5/16 which is the trap drill for a 3/8-16 screw for a 70% tread
I want to know where you got 1/4-42 screw unless you meant 1/4-24 then the tap drill would be a #4 drill.
I'm at work now and looked it up. I can't find a 1/4-42 in my Handbook but here is what I did find
1/4-24 UNS 2B Pitch Dia = .2229-.2277
1/4-40 UNS 2B Pitch Dia= .2338-.2376
1/4-48 UNS 2B Pitch Dia=.2365-.2401
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Unread 08-01-2003, 10:10
Pro E King
#0157 (AZTECHS 157)
1/4 42 is a size I use at my work and the engineers are having trouble getting it with in torerance. I think that have the drill szie wrong thats why i need a formula. I couldn't get my hands on a hand book.
157 The Aztechs
Luck of the Irish
Unread 08-01-2003, 10:50
Let's have fun!
#1022 (ArcherGEeks)
Okay here is a formula (from the Machinery Handbook) for calculating tap drill size.
For American Unified Thread
Hole Size = Basic Major Diameter - ((1.08253*Per Cent Full Thread)/Number of Threads per Inch)
Per Cent full Thread is expressed in decimal form i.e. 75% = .75
Is this what you were looking for??
James Grim
www.youthbotin.org
Unread 08-01-2003, 10:57
Pro E King
#0157 (AZTECHS 157)
Most likely, I'll try it.
157 The Aztechs
Luck of the Irish
need help fast!!! Hubless 1/4 pitch sprockets Travis Covington General Forum 6 03-02-2003 18:44
my idea of a question forum... Ken Leung General Forum 12 30-11-2002 12:17
motor gear pitches archiver 1999 4 23-06-2002 23:09
Chief Delphi Site Question Mike Bonham General Forum 1 16-02-2002 22:18
Rookie Programmer has question about the default code DanL Programming 3 26-01-2002 19:59
